2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: mrkSoftTest doesn't compile
To: EPICS Core Talk <[email protected]>
Date: Mon, 14 Nov 2005 14:55:10 -0600
It works for me on my version of Linux. Mine, however, is getting old
uranus% cat /proc/version
Linux version 2.4.21-9.0.1.EL ([email protected]) (gcc version 3.2.3 20030502 (Red Hat Linux 3.2.3-26)) #1 Mon Feb 9 22:44:14 EST 2004
In
/usr/bin/g++ -o common -L/opt/epics/R3.14.7/support/base/3-14-7-0/lib/linux-x86/ -Wl,-rpath,/opt/epics/R3.14.7/support/base/3-14-7-0/lib/linux-x86 -Wl,-rpath,/home/unix/lange/work/epics/APS/epics/base/3-14-X/lib/linux-x86
Why are there two "-W1" pointing to different versions of base?
Marty
Ralph Lange wrote:
Marty,
mrkSoftTest doesn't compile aymore (neither on HP nor on Linux):
aCC -o access -L/opt/epics/R3.14.7/base/3-14-7-0/lib/hpux-parisc/ -AA -mt -Wl,+b/home/unix/lange/work/epics/APS/epics/base/3-14-X/lib/hpux-parisc:/home/unix/lange/work/epics/APS/epics/extensions/lib/hpux-parisc:/opt/epics/R3.14.7/base/3-14-7-0/lib/hpux-parisc,+s access_registerRecordDeviceDriver.o asinittest.o asTest.o asTrapWriteTest.o accessMain.o -lrecIoc -lsoftDevIoc -liocsh -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
/usr/ccs/bin/ld: Unsatisfied symbols:
pvar_int_dbRecordsOnceOnly (first referenced in access_registerRecordDeviceDriver.o) (data)
On Linux:
/usr/bin/g++ -o common -L/opt/epics/R3.14.7/support/base/3-14-7-0/lib/linux-x86/ -Wl,-rpath,/opt/epics/R3.14.7/support/base/3-14-7-0/lib/linux-x86 -Wl,-rpath,/home/unix/lange/work/epics/APS/epics/base/3-14-X/lib/linux-x86 -Wl,-rpath,/home/unix/lange/work/epics/APS/epics/extensions/lib/linux-x86 devAiAsyn.o common_registerRecordDeviceDriver.o commonMain.o -ltestDevIoc -lrecIoc -lsoftDevIoc -liocsh -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom common_registerRecordDeviceDriver.o(.text+0x4a1): In function `__static_initialization_and_destruction_0': /net/unix/mnt/csr-home/lange/work/epics/APS/epics/mrkSoftTest/common/src/O.linux-x86/common_registerRecordDeviceDriver.cpp:264: undefined reference to `pvar_int_dbRecordsOnceOnly'
I don't see any changes in mrkSoftTest, though. Strange. I'm pretty sure you know faster than me what's wrong ...
Ralph
Build system problem (was: mrkSoftTest doesn't compile) Ralph Lange
mrkSoftTest doesn't compile Ralph Lange
Prev: RE: vxWorks epicsThreadCreate returns valid thread id when thread wasnt created Jeff Hill
Next: R3.14.8/logClient Benjamin Franksen
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: mrkSoftTest doesn't compile Ralph Lange
Next: Build system problem (was: mrkSoftTest doesn't compile) Ralph Lange
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
