2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Network Accessable Types
To: EPICS Core Talk <[email protected]>
Date: Tue, 26 Jul 2005 10:06:22 -0400
On Jul 26, 2005, at 05:49, Ralph Lange wrote:
1. Learning the native type of data is part of the DA interface. The DA interface is purely about data and does not have any notion of network transport. An application may access things within a library or through shared memory using DA without any network involved.
I agree, and if you do,
doesn't it follows that the application
shouldn't have to deal with
possible network buffer boundaries?
The application should see a data interface
that allows random access:
List the properties,
learn that the 5th property is the "value",
typed as some sort of number, then fetch it as a double.
Ask for the "units" property as a string, ...
The V3 channel access library does hide the network
delays and buffer boundaries from me,
I eventually get the full DBR_CTRL_XXX
and can access any piece in there in random order.
(Yes, it requires pre-configuration of the max. array size)
Why should the new data access interface
involve the application in the handling of the
incoming network stream byte-by-byte,
maybe first receiving the time stamp,
then a few initial characters of a string value,
then the next 2 chars, ...?
-Kay
Re: Network Accessable Types Ralph Lange
RE: Network Accessable Types Jeff Hill
Re: Network Accessable Types Marty Kraimer
Re: Network Accessable Types Andrew Johnson
Prev: Re: Network Accessable Types Ralph Lange
Next: Re: Network Accessable Types Ralph Lange
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
