Well, yes. Sure. But: wasn't that the point?!
Maybe I'm misunderstanding the discussion, but for me the line of
argumentation is as follows:
- There will be buffer boundary issues when transferring strings (or
structs or arrays). If one of these things is larger than a buffer - for
sure. Else - only now and then when filling these things into a network
buffer hits the buffer end.
- The user interfaces (APIs) to those things should completely hide
these issues.
- Therefore the implementations of these APIs must be able to cope with
buffer boundary issues, i.e. they must be able to handle storage in
non-contiguous blocks. The interface must allow for such implementations.
If we're trying to agree on one interface, that interface must allow
non-contig.-storage implementations, else CA won't be able to use it.
If we're trying to agree on one implementation that is reusable all over
the place, that implementation must be able to handle non-contiguous
storage, else CA won't be able to use it.
It is desireable to separate the interface from the implementation, as
this would allow other implementations (that might be
smaller/simpler/faster by not supporting non-contig.-storage) to be used
in adequate places while still keeping the same interface.
If we allow something in the interface that requires contiguous storage
(such as c_str), we either restrict the implementation to contiguous
storage (which won't work for network buffers) or force the
implementation to double-buffer everything to have it in a contiguous
place (which is bad in performance and memory fragmentation issues).
Or do I miss something important here?!
Ralph
Kay-Uwe Kasemir wrote:
On Jul 26, 2005, at 05:49, Ralph Lange wrote:
1. Learning the native type of data is part of the DA interface. The
DA interface is purely about data and does not have any notion of
network transport. An application may access things within a library
or through shared memory using DA without any network involved.
I agree, and if you do,
doesn't it follows that the application
shouldn't have to deal with
possible network buffer boundaries?
The application should see a data interface
that allows random access:
List the properties,
learn that the 5th property is the "value",
typed as some sort of number, then fetch it as a double.
Ask for the "units" property as a string, ...
The V3 channel access library does hide the network
delays and buffer boundaries from me,
I eventually get the full DBR_CTRL_XXX
and can access any piece in there in random order.
(Yes, it requires pre-configuration of the max. array size)
Why should the new data access interface
involve the application in the handling of the
incoming network stream byte-by-byte,
maybe first receiving the time stamp,
then a few initial characters of a string value,
then the next 2 chars, ...?
-Kay
Ralph Lange [email protected] Tel: +49 30 6392-2117
BESSY Controls Group www.bessy.de Fax: ... -4859
- Re: Network Accessable Types Kay-Uwe Kasemir
- RE: Network Accessable Types Jeff Hill
- Re: Network Accessable Types Marty Kraimer
- Re: Network Accessable Types Andrew Johnson
- Re: Network Accessable Types Ralph Lange
<2005>
<2005>
