Any comments or arguments about placing these requirements on CA?
1. Each version of the CA protocol SHALL document which data
types it supports for transporting properties over the wire.
2. Each version of every implementation of the CA library,
server or client, whatever language it supports, SHALL
document which version of the protocol it supports, and how
the on-the-wire data types from the protocol are mapped to
the data types provided by that language.
3. A client application written in any language SHALL be able
to find out the on-the-wire data type which is used to send
any specific property being received through the CA transport.
Note that in #3 I'm *not* requiring CA to be able to transport the
type of the property as implemented in the language of the server,
only the on-the-wire representation it supplies for that property.
Since different languages support different sets of types and may map
several different on-the-wire types to the same language-specific
type, some language implementations will have to to encode the
wire-type into something that can be represented as a *value* in a
language-specific data type. It would seem sensible to be able to
reuse the same value that is used internally by the network transport,
suitably converted.
I have the feeling we are mixing up things that belong to different
layers here.
While I generally agree with your requirements and descriptions, I don't
think we should make the network layer's on-the-wire types the central
type-defining instance. Let me give two reasons:
1. Learning the native type of data is part of the DA interface. The DA
interface is purely about data and does not have any notion of network
transport. An application may access things within a library or through
shared memory using DA without any network involved. Why should a
certain network layer define the data types when no network is used?
2. Not only may a language map different on-the-wire types to the same
language-specific type, CA (or another network layer) itself might
consider to map different language specific-types to the same
on-the-wire type. In that case I would like the client to know the real
original native type of data on the server side and /not/ what something
inbetween chose to use for network transport.
I see the next generation CA as a transparent network transport layer
for DA accessible data, so that the DA interface works the same local
and via network. A client application should not have to know and should
not even care what on-the-wire types CA uses to transport stuff.
I.e., we still need a well-defined extensible set of data types and
should continue the discussion how this should be implemented. But: I
would rather like to keep that set-of-types definition completely
independent from CA.
A CA (or any other network transport) server should be free to choose
the on-the-wire representation for any given DA accessible data, based
on the native types that it gets from the surveyor. It should
transparently forward the original native type info to the client side,
so that a client app gets the same results from the surveyor when
reading over the network as when reading locally.
Does that make sense?
Ralph
- Re: Network Accessable Types Kay-Uwe Kasemir
- Re: Network Accessable Types Andrew Johnson
- RE: Network Accessable Types Jeff Hill
- Re: Network Accessable Types Marty Kraimer
Data Interfaces Kay-Uwe Kasemir
<2005>
<2005>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
