2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Network Accessable Types
To: EPICS Core Talk <[email protected]>
Date: Tue, 26 Jul 2005 17:05:30 +0200
Kay-Uwe Kasemir wrote:
On Jul 26, 2005, at 05:49, Ralph Lange wrote:
1. Learning the native type of data is part of the DA interface. The DA interface is purely about data and does not have any notion of network transport. An application may access things within a library or through shared memory using DA without any network involved.
The application should see a data interface
that allows random access:
List the properties,
learn that the 5th property is the "value",
typed as some sort of number, then fetch it as a double.
Ask for the "units" property as a string, ...
I don't see your point here, as all this is true for Data Access (assuming that the surveyor yields something comprehensive and /not/ just empty objects):
- The traverse methods will list properties and types (surveyor)
- The find method will fetch a property by name (the viewer will convert it to the format of your local storage)
The knowledge that something is "the 5th" property in a catalog does not hold any information, as all access is only by property name/id. Of course your app may count and number properties any way it wants. (Data Access does not preclude you from counting properties. ;-)
Ralph
RE: Network Accessable Types Jeff Hill
Re: Network Accessable Types Marty Kraimer
Re: Network Accessable Types Andrew Johnson
Re: Network Accessable Types Ralph Lange
Re: Network Accessable Types Kay-Uwe Kasemir
Prev: Re: Network Accessable Types Ralph Lange
Next: Re: Network Accessable Types Kay-Uwe Kasemir
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Network Accessable Types Andrew Johnson
Next: Re: Network Accessable Types Andrew Johnson
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
