Heinz/Lin,
Unfortunately I've only ever built ca2aa against the debian package repo for
channelarchiver. I just verified that, after making some gcc6 and Base3.15 changes,
it and ca2aa build, and ca2aa passes tests.
I'm not sure of the relationship between https://github.com/EPICSTools/ChannelArchiver
and https://github.com/epicsdeb/channelarchiver.git
The epicsdeb repo originated from a tarfile with a 2.9.2 version number.
Of course, I may not have started with the latest version (back in 2010).
The EPICSTools repo carries a version number 3.0.0 (see make.cfg). Which suggests
that it's more recent. Unfortunately, the last tag is from 2008, so it isn't
straightforward for me to say more.
As far as ca2aa is concerned, unless the on disk format has changed
it shouldn't make a difference which version it is built against.
Michael
On 12/16/2017 05:27 AM, Heinz Junkes wrote:
> I'm trying to compile pbeApp which is part of ca2a and get the following error:
> /usr/bin/g++ -c -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -m64 -MMD -I. -I../O.Common -I. -I.. -I../../include/os/Linux -I../../include -I/home/epics/EPICS/base/include/os/Linux -I/home/epics/EPICS/base/include -I/home/epics/EPICS/extensions/include -I/home/epics/EPICS/extensions/src/ChannelArchiver/Storage ../listpvs.cpp
> ../listpvs.cpp: In function ‘int main(int, char**)’:
> ../listpvs.cpp:38:25: error: cannot declare variable ‘iter’ to be of abstract type ‘Index::NameIterator’
> Index::NameIterator iter;
> In file included from /home/epics/EPICS/extensions/src/ChannelArchiver/Storage/ReaderFactory.h:9:0,
> from /home/epics/EPICS/extensions/src/ChannelArchiver/Storage/SpreadsheetReader.h:7,
> from ../listpvs.cpp:26:
> /home/epics/EPICS/extensions/src/ChannelArchiver/Storage/Index.h:104:11: note: because the following virtual functions are pure within ‘Index::NameIterator’:
> class NameIterator
> /home/epics/EPICS/extensions/src/ChannelArchiver/Storage/Index.h:110:22: note: virtual bool Index::NameIterator::isValid() const
> virtual bool isValid() const = 0;
> /home/epics/EPICS/extensions/src/ChannelArchiver/Storage/Index.h:113:34: note: virtual const stdString& Index::NameIterator::getName() const
> virtual const stdString &getName() const = 0;
> /home/epics/EPICS/extensions/src/ChannelArchiver/Storage/Index.h:118:23: note: virtual void Index::NameIterator::next()
> virtual void next() = 0;
> ../listpvs.cpp:39:13: error: ‘class AutoIndex’ has no member named ‘getFirstChannel’; did you mean ‘findChannel’?
> if(!idx.getFirstChannel(iter)) {
> ../listpvs.cpp:46:16: error: ‘class AutoIndex’ has no member named ‘getNextChannel’; did you mean ‘addChannel’?
> }while(idx.getNextChannel(iter));
> /home/epics/EPICS/base/configure/RULES_BUILD:221: recipe for target 'listpvs.o' failed
> make[2]: *** [listpvs.o] Error 1
> Heinz
>> On 15. Dec 2017, at 16:42, Michael Davidsaver <[email protected]> wrote:
>> You might also try https://github.com/epicsdeb/channelarchiver which is what I developed/tested my
>> ca2aa converter against.
>> On 12/15/2017 04:49 AM, Wang, Lin wrote:
>>> Hello Kay,
>>> I would like to build a Channel Archiver test environment to investigate data migration to Archiver Appliance.
>>> When I built the latest Channel Archiver source code from github [1] within EPICS_BASE/src directory, I encountered the following error:
>>> /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -D ARCH_VERSION=3 -D ARCH_RELEASE=0 -D ARCH_PATCH=0 -D ARCH_VERSION_TXT=\"3.0.0\" -I../../../../include -I../../../../include/os/Linux -I/usr/local/include -DFUX_XERCES -m64 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../AVLTreeTest.cpp
>>> In file included from ../AVLTreeTest.cpp:4:0:
>>> ../AVLTree.h: In instantiation of ‘bool AVLTree<Item>::find(Item&) [with Item = int]’:
>>> ../AVLTreeTest.cpp:37:24: required from here
>>> ../AVLTree.h:80:46: error: ‘sort_compare’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
>>> comp = sort_compare(item, n->item);
>>> ../AVLTreeTest.cpp:7:12: note: ‘int sort_compare(const int&, const int&)’ declared here, later in the translation unit
>>> static int sort_compare(const int &a, const int &b)
>>> ../AVLTree.h: In instantiation of ‘bool AVLTree<Item>::insert(AVLItem<Item>*, AVLItem<Item>**) [with Item = int]’:
>>> ../AVLTree.h:61:28: required from ‘void AVLTree<Item>::add(const Item&) [with Item = int]’
>>> ../AVLTreeTest.cpp:31:24: required from here
>>> ../AVLTree.h:168:62: error: ‘sort_compare’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
>>> int comp = sort_compare(new_node->item, (*node)->item);
>>> ../AVLTree.h: In instantiation of ‘void AVLTree<Item>::print_dot_node(FILE*, AVLItem<Item>*, int&) [with Item = int; FILE = _IO_FILE]’:
>>> ../AVLTree.h:286:34: required from ‘void AVLTree<Item>::make_dotfile(const char*) [with Item = int]’
>>> ../AVLTreeTest.cpp:49:28: required from here
>>> ../AVLTree.h:220:40: error: ‘toString’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
>>> me, toString(node->item), (int)node->balance);
>>> ../AVLTreeTest.cpp:20:20: note: ‘const char* toString(const int&)’ declared here, later in the translation unit
>>> static const char *toString(const int &i)
>>> ../../../../configure/RULES_BUILD:209: recipe for target 'AVLTreeTest.o' failed
>>> make[2]: *** [AVLTreeTest.o] Error 1
>>> make[2]: Leaving directory '/home/wanglin/base-3.14.12.3/src/ChannelArchiver/Tools/O.linux-x86_64'
>>> ../../../configure/RULES_ARCHS:63: recipe for target 'install.linux-x86_64' failed
>>> make[1]: *** [install.linux-x86_64] Error 2
>>> make[1]: Leaving directory '/home/wanglin/base-3.14.12.3/src/ChannelArchiver/Tools'
>>> ../../configure/RULES_DIRS:70: recipe for target 'Tools.install' failed
>>> make: *** [Tools.install] Error 2
>>> If I move sort_compare() and toString() methods to the position before "#include AVLTree.h" in Tools/AVLTreeTest.cpp as follows, the problem is gone.
>>> #include <stdio.h>
>>> #include <stdlib.h>
>>> { return b-a; }
>>> static char txt[10];
>>> sprintf(txt, "%d", i);
>>> return txt;
>>> #include "AVLTree.h"
>>> #include "UnitTest.h"
>>> static int avl_last_number;
>>> static bool tree_is_ordered;
>>> static void avl_order_test(const int &i, void *)
>>> if (i < avl_last_number)
>>> tree_is_ordered = false;
>>> avl_last_number = i;
>>> Will this workaround cause any issue? Is there any other solution recommended?
>>> My platform is Debian 8 (Jessie), gcc/g++ 4.9.2
>>> Thanks,
>>> Lin
>>> [1] https://github.com/EPICSTools/ChannelArchiver
- Re: Channel Archiver compilation error Heinz Junkes
- Channel Archiver compilation error Wang, Lin
- Re: Channel Archiver compilation error Michael Davidsaver
Re: Puzzled with lockset(?) problem Michael Davidsaver
Helium Purity Sensors austen.rose
<2017>
<2017>
