You might also try https://github.com/epicsdeb/channelarchiver which is what I developed/tested my
ca2aa converter against.
On 12/15/2017 04:49 AM, Wang, Lin wrote:
> Hello Kay,
> I would like to build a Channel Archiver test environment to investigate data migration to Archiver Appliance.
> When I built the latest Channel Archiver source code from github [1] within EPICS_BASE/src directory, I encountered the following error:
> /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -g -Wall -D ARCH_VERSION=3 -D ARCH_RELEASE=0 -D ARCH_PATCH=0 -D ARCH_VERSION_TXT=\"3.0.0\" -I../../../../include -I../../../../include/os/Linux -I/usr/local/include -DFUX_XERCES -m64 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../AVLTreeTest.cpp
> In file included from ../AVLTreeTest.cpp:4:0:
> ../AVLTree.h: In instantiation of ‘bool AVLTree<Item>::find(Item&) [with Item = int]’:
> ../AVLTreeTest.cpp:37:24: required from here
> ../AVLTree.h:80:46: error: ‘sort_compare’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
> comp = sort_compare(item, n->item);
> ../AVLTreeTest.cpp:7:12: note: ‘int sort_compare(const int&, const int&)’ declared here, later in the translation unit
> static int sort_compare(const int &a, const int &b)
> ../AVLTree.h: In instantiation of ‘bool AVLTree<Item>::insert(AVLItem<Item>*, AVLItem<Item>**) [with Item = int]’:
> ../AVLTree.h:61:28: required from ‘void AVLTree<Item>::add(const Item&) [with Item = int]’
> ../AVLTreeTest.cpp:31:24: required from here
> ../AVLTree.h:168:62: error: ‘sort_compare’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
> int comp = sort_compare(new_node->item, (*node)->item);
> ../AVLTree.h: In instantiation of ‘void AVLTree<Item>::print_dot_node(FILE*, AVLItem<Item>*, int&) [with Item = int; FILE = _IO_FILE]’:
> ../AVLTree.h:286:34: required from ‘void AVLTree<Item>::make_dotfile(const char*) [with Item = int]’
> ../AVLTreeTest.cpp:49:28: required from here
> ../AVLTree.h:220:40: error: ‘toString’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
> me, toString(node->item), (int)node->balance);
> ../AVLTreeTest.cpp:20:20: note: ‘const char* toString(const int&)’ declared here, later in the translation unit
> static const char *toString(const int &i)
> ../../../../configure/RULES_BUILD:209: recipe for target 'AVLTreeTest.o' failed
> make[2]: *** [AVLTreeTest.o] Error 1
> make[2]: Leaving directory '/home/wanglin/base-3.14.12.3/src/ChannelArchiver/Tools/O.linux-x86_64'
> ../../../configure/RULES_ARCHS:63: recipe for target 'install.linux-x86_64' failed
> make[1]: *** [install.linux-x86_64] Error 2
> make[1]: Leaving directory '/home/wanglin/base-3.14.12.3/src/ChannelArchiver/Tools'
> ../../configure/RULES_DIRS:70: recipe for target 'Tools.install' failed
> make: *** [Tools.install] Error 2
> If I move sort_compare() and toString() methods to the position before "#include AVLTree.h" in Tools/AVLTreeTest.cpp as follows, the problem is gone.
> #include <stdio.h>
> #include <stdlib.h>
> { return b-a; }
> static char txt[10];
> sprintf(txt, "%d", i);
> return txt;
> #include "AVLTree.h"
> #include "UnitTest.h"
> static int avl_last_number;
> static bool tree_is_ordered;
> static void avl_order_test(const int &i, void *)
> if (i < avl_last_number)
> tree_is_ordered = false;
> avl_last_number = i;
> Will this workaround cause any issue? Is there any other solution recommended?
> My platform is Debian 8 (Jessie), gcc/g++ 4.9.2
> Thanks,
> Lin
> [1] https://github.com/EPICSTools/ChannelArchiver
- Re: Channel Archiver compilation error Heinz Junkes
- Channel Archiver compilation error Wang, Lin
Puzzled with lockset(?) problem Dirk Zimoch
<2017>
<2017>
