I attach a file showing my efforts at setting this variable in the xterm session in which I run my caxyz commands and the record of my puzzling problems. Before trying to export these values of EPICS_CA_ADDR_LIST, all was well. Whereas, after setting it, failingx2, if I unset it I can not connect: I am not returning to successful camonitoring of just even one IOC.
Note: all the relevant-looking complaints from my 2nd IOC terminal in the attached file ….
- Eric
On 12/5/17, 1:43 PM, "Mark Rivers" <[email protected]> wrote:
> Looks like the EPICS_CA_ADDR_LIST used by camonitor is not using the broadcast address of your host.
It should be doing that automatically without you needing to set EPICS_CA_ADDR_LIST. Can you send the output of the following commands Linux command in the shell where you are running camonitor.
ifconfig
printenv | grep EPICS
At the IOC shell prompt on both the first and second IOCs send the output of
epicsPrtEnvParams
What happens if you set EPICS_CA_ADDR_LIST manually to the broadcast address of your system? For example on my system ifconfig shows:
p5p1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 164.54.160.82 netmask 255.255.255.0 broadcast 164.54.160.255
inet6 fe80::3efd:feff:fea3:f258 prefixlen 64 scopeid 0x20<link>
ether 3c:fd:fe:a3:f2:58 txqueuelen 1000 (Ethernet)
RX packets 80276465019 bytes 92598173910474 (84.2 TiB)
RX errors 0 dropped 114 overruns 0 frame 0
TX packets 32261858165 bytes 16671972218313 (15.1 TiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
So I would set EPICS_CA_ADDR_LIST=164.54.160.255
> -----Original Message-----
> From: Kasemir, Kay [mailto:[email protected]]
> Sent: Tuesday, December 05, 2017 3:37 PM
> To: Church, Eric D; Mark Rivers; Ralph Lange; EPICS Tech Talk
> Cc: Mendez, Jennifer M
> Subject: Re: caget() from C++
> >Indeed camonitor can properly watch a channel on the first IOC when only it is running. I
> can dial up and down the voltage from CSS on a particular PV on this first IOC and watch
> it move on camonitor. >When I start the second IOC I can continue this exercise on POVs
> on the first IOC. If I kill camonitor, per your suggestion, I can not start it again on a PV on
> the first IOC. And if I kill the second IOC I can >once again start camonitor successfully on
> a PV on the first IOC.
> >What does it mean, do ya think?
arxe:~/ara/CSS$ ifconfig
eth0 Link encap:Ethernet HWaddr 00:80:2F:19:FE:07
inet addr:130.20.48.81 Bcast:130.20.49.255 Mask:255.255.254.0
inet6 addr: fe80::280:2fff:fe19:fe07/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:18620331 errors:0 dropped:0 overruns:0 frame:0
TX packets:7828704 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2781070185 (2.5 GiB) TX bytes:1383464993 (1.2 GiB)
Interrupt:20 Memory:dfe00000-dfe20000
eth1 Link encap:Ethernet HWaddr 00:80:2F:19:FE:08
inet addr:192.168.1.11 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::280:2fff:fe19:fe08/64 Scope:Link
RX packets:332650789 errors:0 dropped:0 overruns:0 frame:0
TX packets:91082275 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:22888828435 (21.3 GiB) TX bytes:7836090071 (7.2 GiB)
Interrupt:19 Memory:dfc60000-dfc80000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:127738385 errors:0 dropped:0 overruns:0 frame:0
TX packets:127738385 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:12824308258 (11.9 GiB) TX bytes:12824308258 (11.9 GiB)
virbr0 Link encap:Ethernet HWaddr 52:54:00:7E:DA:94
inet addr:192.168.122.1 Bcast:192.168.122.255 Mask:255.255.255.0
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:21796 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 b) TX bytes:12474520 (11.8 MiB)
arxe:~/ara/CSS$ export EPICS_CA_ADDR_LIST=192.168.1.255
arxe:~/ara/CSS$ camonitor PS1304001:000:vmon
Warning: Duplicate EPICS CA Address list entry "192.168.1.255:5064" discarded
PS1304001:000:vmon *** Not connected (PV not found)
^C
arxe:~/ara/CSS$ export EPICS_CA_ADDR_LIST=130.20.49.255
Warning: Duplicate EPICS CA Address list entry "130.20.49.255:5064" discarded
^C
arxe:~/ara/CSS$ printenv | grep EPICS
.30+6.
PYEPICS_LIBCA=/home/arxe/ara/epics/base-3.14.12.5/lib/linux-x86_64/libca.so
EPICS_HOST_ARCH=linux-x86_64
..............Now, onto the IOC epicsPrtEnvParams request:
---- 1st IOC ----
epics> epicsPrtEnvParams
EPICS_AR_PORT: 7002
EPICS_CAS_AUTO_BEACON_ADDR_LIST is undefined
EPICS_CAS_BEACON_ADDR_LIST is undefined
EPICS_CAS_BEACON_PERIOD is undefined
EPICS_CAS_BEACON_PORT is undefined
EPICS_CAS_IGNORE_ADDR_LIST is undefined
EPICS_CAS_INTF_ADDR_LIST is undefined
EPICS_CAS_SERVER_PORT is undefined
EPICS_CA_ADDR_LIST is undefined
EPICS_CA_AUTO_ADDR_LIST: YES
EPICS_CA_BEACON_PERIOD: 15.0
EPICS_CA_CONN_TMO: 30.0
EPICS_CA_MAX_ARRAY_BYTES: 16384
EPICS_CA_MAX_SEARCH_PERIOD: 300.0
EPICS_CA_NAME_SERVERS is undefined
EPICS_CA_REPEATER_PORT: 5065
EPICS_CA_SERVER_PORT: 5064
EPICS_CMD_PROTO_PORT is undefined
EPICS_IOC_LOG_FILE_COMMAND is undefined
EPICS_IOC_LOG_FILE_LIMIT: 1000000
EPICS_IOC_LOG_FILE_NAME is undefined
EPICS_IOC_LOG_INET is undefined
EPICS_IOC_LOG_PORT: 7004
EPICS_TIMEZONE: CUS::360:031302:110602
EPICS_TS_NTP_INET is undefined
IOCSH_HISTSIZE: 50
IOCSH_PS1: epics>
epics>
--- 2nd IOC -----
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 42117,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
## Start any sequence programs
#seq sncxxx,"PSNAME=PS1304001"
EPICS_AR_PORT: 7002
IOCSH_HISTSIZE: 50
IOCSH_PS1: epics>
epics>
- RE: caget() from C++ Mark Rivers
- caget() from C++ Church, Eric D
- Re: caget() from C++ Andrew Johnson
- Re: caget() from C++ Church, Eric D
- Re: caget() from C++ Mark Rivers
- Re: caget() from C++ Ralph Lange
- Re: caget() from C++ Kasemir, Kay
RE: EPICS 7 Release Candidate 1 Mark Engbretson
<2017>
<2017>
