Hi Eric,
From: Church, Eric D <[email protected]> (3) I point out my CSS is fine. Sometimes it can not see the PVs on the IOC that I can also not cainfo into, but a restart of the IOC fixes that, and CSS is fully functional to monitor and control all my PVs. CS-Studio and probably your archive engine are Java applications. The command line utilities are binaries (compiled from C/C++). The configuration mechanisms between Java applications and C/C++ binaries are different. Unless you explicitly configure both the same way, it is expected that only changing the configuration for one type of applications will not affect the other. Cheers, ~Ralph
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
