> Looks like the EPICS_CA_ADDR_LIST used by camonitor is not using the broadcast address of your host.
It should be doing that automatically without you needing to set EPICS_CA_ADDR_LIST. Can you send the output of the following commands Linux command in the shell where you are running camonitor.
ifconfig
printenv | grep EPICS
At the IOC shell prompt on both the first and second IOCs send the output of
epicsPrtEnvParams
What happens if you set EPICS_CA_ADDR_LIST manually to the broadcast address of your system? For example on my system ifconfig shows:
p5p1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 164.54.160.82 netmask 255.255.255.0 broadcast 164.54.160.255
inet6 fe80::3efd:feff:fea3:f258 prefixlen 64 scopeid 0x20<link>
ether 3c:fd:fe:a3:f2:58 txqueuelen 1000 (Ethernet)
RX packets 80276465019 bytes 92598173910474 (84.2 TiB)
RX errors 0 dropped 114 overruns 0 frame 0
TX packets 32261858165 bytes 16671972218313 (15.1 TiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
So I would set EPICS_CA_ADDR_LIST=164.54.160.255
> -----Original Message-----
> From: Kasemir, Kay [mailto:[email protected]]
> Sent: Tuesday, December 05, 2017 3:37 PM
> To: Church, Eric D; Mark Rivers; Ralph Lange; EPICS Tech Talk
> Cc: Mendez, Jennifer M
> Subject: Re: caget() from C++
> >Indeed camonitor can properly watch a channel on the first IOC when only it is running. I
> can dial up and down the voltage from CSS on a particular PV on this first IOC and watch
> it move on camonitor. >When I start the second IOC I can continue this exercise on POVs
> on the first IOC. If I kill camonitor, per your suggestion, I can not start it again on a PV on
> the first IOC. And if I kill the second IOC I can >once again start camonitor successfully on
> a PV on the first IOC.
> >What does it mean, do ya think?
- Re: caget() from C++ Church, Eric D
- caget() from C++ Church, Eric D
- Re: caget() from C++ Andrew Johnson
- Re: caget() from C++ Mark Rivers
- RE: caget() from C++ Mark Rivers
- Re: caget() from C++ Ralph Lange
- Re: caget() from C++ Kasemir, Kay
<2017>
<2017>
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
