1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Use case for ao record HOPR != DRVH or LOPR != DRVL?
To: EPICS Tech Talk <[email protected]>
Date: Tue, 30 May 2017 19:32:38 +0200
I have used both variants:
1. xOPR wider than DRVx
Device should be drive limited to a specific value, e.g. 785mA (was a filament heater of an expensive RF tube). However, for consistency reasons, the widgets on all panels for the standard 1A power supply being used should show the same limits as all other 1A power supplies, i.e. 1A.
2. xOPR narrower than DRVx
While the device is technically capable of handling a setting of e.g. 0..12V, regular operators using GUI tools should use 0..10V and only apply 10..12V settings when talking to the device expert on the phone. Sliders will stop at the xOPR setting, right click or caput setting works up to the technically allowed limit.
Note that by using defaults in the database file, you can define things like
  field(DRVH,"$(DRVH=$(HOPR))")
which will set DRVH to $HOPR unless $DRVH is defined.
Cheers,
~Ralph
Use case for ao record HOPR != DRVH or LOPR != DRVL? J. Lewis Muir
Prev: Re: Use case for ao record HOPR != DRVH or LOPR != DRVL? Andrew Johnson
Next: the pv in sscan disconnect 梁雅翔
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: Use case for ao record HOPR != DRVH or LOPR != DRVL? Mooney, Tim M.
Next: Re: Use case for ao record HOPR != DRVH or LOPR != DRVL? Nicholas P. DiMonte
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
