1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Use case for ao record HOPR != DRVH or LOPR != DRVL?
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 30 May 2017 11:41:38 -0500
Hello, Tech-Talkers!
I understand that for the ao (Analog Output) record, the HOPR and LOPR
fields are used for the display limits and the DRVH and DRVL fields are
used for the control limits.  However, I always end up setting HOPR =
DRVH and LOPR = DRVL.  What's a use case where the display limits would
be different from the control limits (i.e., HOPR != DRVH or LOPR !=
DRVL)?
Thanks!
Lewis
RE: Use case for ao record HOPR != DRVH or LOPR != DRVL? Mark Rivers
Re: Use case for ao record HOPR != DRVH or LOPR != DRVL? Mooney, Tim M.
Re: Use case for ao record HOPR != DRVH or LOPR != DRVL? Ralph Lange
Re: Use case for ao record HOPR != DRVH or LOPR != DRVL? Nicholas P. DiMonte
Prev: Re: alh Rod Nussbaumer
Next: RE: Use case for ao record HOPR != DRVH or LOPR != DRVL? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: RE: Configuring multiple ports with variable port numbers for StreamDevice Mark Rivers
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
