1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Base Release-Candidate Double Feature!
Date: Sat, 12 Nov 2016 17:03:06 +0000
Hi Freddie,
Thanks, I will commit that change on Monday. I copied that code including the conditional from one of the test programs in 3.15 src/ioc/db/test though, so I'm wondering how you didn't see a build failure with VS2015 there – could you investigate please?
- Andrew
Sent from my iPad
> On Nov 12, 2016, at 8:06 AM, "[email protected]" <[email protected]> wrote:
> Hi Andrew,
> Your patch does indeed fix the formatting  problem present in earlier versions of Visual Studio, but it appears that when Microsoft corrected this issue in Visual Studio 2015 they decided to remove the  _set_output_format()  function at the same time! So I just needed to adjust the test to:
> #if defined(_WIN32)
> #if    (defined(_MINGW) &&  __MSVCRT_VERSION__ >= 0x0800) ||  \
>              (defined(_MSC_VER) && _MSC_VER < 1900)
>    _set_output_format(_TWO_DIGIT_EXPONENT);
> #endif
> #endif /* defined(_WIN32) */
> and then it works OK with both VS 2010 and 2015 for     testPlan(163)
> Regards,
> Freddie
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: 11 November 2016 20:43
> To: Akeroyd, Freddie (STFC,RAL,ISIS); [email protected]
> Hi Freddie,
>> On 11/10/2016 05:52 PM, [email protected] wrote:
>> epicsStdioTest.c plans 166 tests on Windows but 163 otherwise, if I
>> build using Visual Studio 2010 instead 166 tests passed OK. On further
>> investigation it seems the issue occurs within
>> testEpicsSnprintf() and is due to Microsoft changing (fixing) the
>> formatting  of "%8.2e" by sprint():
>> In Visual Studio 2010 this generates    1.23e+004
>> In Visual Studio 2015 this generates    1.23e+04
> Thanks for the report. Does this patch make the test pass on both compilers?
> === modified file 'src/libCom/test/epicsStdioTest.c'
> --- src/libCom/test/epicsStdioTest.c    2012-02-03 22:12:06 +0000
> +++ src/libCom/test/epicsStdioTest.c    2016-11-11 20:40:36 +0000
> @@ -39,6 +39,11 @@
>     int size;
>     int rtn, rlen;
> +#if defined(WIN32) && \
> +    (!defined(_MINGW) || __MSVCRT_VERSION__ >= 0x0800)
> +    _set_output_format(_TWO_DIGIT_EXPONENT);
> +#endif
>     sprintf(exbuffer, format, ivalue, fvalue, svalue);
>     rlen = strlen(expected)+1;
> @@ -122,11 +127,7 @@
> MAIN(epicsStdioTest)
> -#ifdef _WIN32
> -    testPlan(166);
> -#else
>     testPlan(163);
> -#endif
>     testEpicsSnprintf();
>     testStdoutRedir("report");
>     return testDone();
> - Andrew
> Arguing for surveillance because you have nothing to hide is no different than making the claim, "I don't care about freedom of speech because I have nothing to say." -- Edward Snowdon
RE: EPICS Base Release-Candidate Double Feature! freddie.akeroyd
EPICS Base Release-Candidate Double Feature! Andrew Johnson
Re: EPICS Base Release-Candidate Double Feature! Andrew Johnson
Prev: RE: EPICS Base Release-Candidate Double Feature! freddie.akeroyd
Next: an easy quesiton about optics l123173
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: RE: EPICS Base Release-Candidate Double Feature! freddie.akeroyd
ANJ, 13 Nov 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
