Hi Andrew,
Sorry, I didn't refer to this in my original reply, but I had also changed the first line from "#if defined(WIN32)" to "#if defined(_WIN32)" as "WIN32" is not defined by Visual Studio (it is by MinGW though in addition to _WIN32). So the 3.15 test program it was taken from builds with VS 2015 as it never actually tries to call _set_output_format() .
Freddie
-----Original Message-----
From: Johnson, Andrew N. [mailto:[email protected]]
Sent: 12 November 2016 17:03
To: Akeroyd, Freddie (STFC,RAL,ISIS)
Cc: [email protected]
Subject: Re: EPICS Base Release-Candidate Double Feature!
Hi Freddie,
Thanks, I will commit that change on Monday. I copied that code including the conditional from one of the test programs in 3.15 src/ioc/db/test though, so I'm wondering how you didn't see a build failure with VS2015 there - could you investigate please?
- Andrew
Sent from my iPad
> On Nov 12, 2016, at 8:06 AM, "[email protected]" <[email protected]> wrote:
> Hi Andrew,
> Your patch does indeed fix the formatting problem present in earlier versions of Visual Studio, but it appears that when Microsoft corrected this issue in Visual Studio 2015 they decided to remove the _set_output_format() function at the same time! So I just needed to adjust the test to:
> #if defined(_WIN32)
> #if (defined(_MINGW) && __MSVCRT_VERSION__ >= 0x0800) || \
> (defined(_MSC_VER) && _MSC_VER < 1900)
> _set_output_format(_TWO_DIGIT_EXPONENT);
> #endif
> #endif /* defined(_WIN32) */
> and then it works OK with both VS 2010 and 2015 for testPlan(163)
> Regards,
> Freddie
> From: Andrew Johnson [mailto:[email protected]]
> Sent: 11 November 2016 20:43
> To: Akeroyd, Freddie (STFC,RAL,ISIS); [email protected]
> Hi Freddie,
>> On 11/10/2016 05:52 PM, [email protected] wrote:
>> epicsStdioTest.c plans 166 tests on Windows but 163 otherwise, if I
>> build using Visual Studio 2010 instead 166 tests passed OK. On
>> further investigation it seems the issue occurs within
>> testEpicsSnprintf() and is due to Microsoft changing (fixing) the
>> formatting of "%8.2e" by sprint():
>> In Visual Studio 2010 this generates 1.23e+004
>> In Visual Studio 2015 this generates 1.23e+04
> Thanks for the report. Does this patch make the test pass on both compilers?
> === modified file 'src/libCom/test/epicsStdioTest.c'
> --- src/libCom/test/epicsStdioTest.c 2012-02-03 22:12:06 +0000
> +++ src/libCom/test/epicsStdioTest.c 2016-11-11 20:40:36 +0000
> @@ -39,6 +39,11 @@
> int size;
> int rtn, rlen;
> +#if defined(WIN32) && \
> + (!defined(_MINGW) || __MSVCRT_VERSION__ >= 0x0800)
> + _set_output_format(_TWO_DIGIT_EXPONENT);
> +#endif
> sprintf(exbuffer, format, ivalue, fvalue, svalue);
> rlen = strlen(expected)+1;
> @@ -122,11 +127,7 @@
> MAIN(epicsStdioTest)
> -#ifdef _WIN32
> - testPlan(166);
> -#else
> testPlan(163);
> -#endif
> testEpicsSnprintf();
> testStdoutRedir("report");
> return testDone();
> - Andrew
> Arguing for surveillance because you have nothing to hide is no
> different than making the claim, "I don't care about freedom of speech
> because I have nothing to say." -- Edward Snowdon
- Re: EPICS Base Release-Candidate Double Feature! Matt Rippa
- EPICS Base Release-Candidate Double Feature! Andrew Johnson
- RE: EPICS Base Release-Candidate Double Feature! freddie.akeroyd
- Re: EPICS Base Release-Candidate Double Feature! Andrew Johnson
- Re: EPICS Base Release-Candidate Double Feature! Johnson, Andrew N.
RE: an easy quesiton about optics Mark Rivers
mutex lock assertion failure Christian Pulvermacher
<2016>
<2016>
