1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Tue, 27 Sep 2016 07:59:03 +0000
Hi Tim,
> But I do have one question already.  For registers added to the FPGA, all one
> needs is the physical address and a call to mmap(), and those registers are
> available to user-space code. Is this because memory added to the FPGA is
> unknown to the cache?
I'm a little bit vague about the details, but in essence this is right.  I think the kernel is configured to set up all of memory as cacheable and the remaining address space as uncacheable.  On our system /proc/iomem shows address space 00000000-3fffffff as System RAM and the rest as various bits of IO space.  Actually, I think this information is probably in the device tree, come to think of it.
>  If so, it there a way to tell the cache not to look at a
> section of the processor's physical memory, so the same strategy might also
> work there?
There probably is, and it's probably not a great idea!  You could in principle tell the kernel to reserver a dedicated block of memory for IO on booting, or you could probably mark memory as uncacheable in chunks after allocating it with __get_free_pages(), but it certainly wouldn't be easier than the recipe I've suggested!  Also, reading from uncached memory is liable to be *very* slow.
I think that it's normally better to cooperate with the cache rather than bypassing it, and I suspect you'd need to dig deeper into the kernel than I ever have to do this right.  I can give you some sample code for an unrelated Zynq project if it would help you, but you'd need to completely rewrite it for your application, of course.
On the device tree, it is mostly a closed book to me, but I see this entry in mine:
	memory { device_type = "memory"; reg = <0x0 0x40000000>; };
This is consistent with the iomem entry.
RE: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe Madden, Timothy J.
Re: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe Pete Jemian
Re: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe D Peter Siddons
Re: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe Steve Shoaf
RE: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe Mooney, Tim M.
RE: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe michael.abbott
Prev: RE: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe Mooney, Tim M.
Next: Problem in 3.14.12.5 with osd/WIN32/osdTime.h with latest version of MinGW Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe Madden, Timothy J.
ANJ, 27 Sep 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
