I found a problem compiling 3.14.12.5 (with the msvs-timespec.patch) when building with the latest version of MinGW on Windows, which is gcc 5.3.0.
This is the error:
g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/
libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../
../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/
libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libC
om/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/fdmgr/fdmgr.
cpp
In file included from ../../../src/libCom/osi/epicsTime.h:19:0,
from ../../../src/libCom/fdmgr/fdManager.h:27,
from ../../../src/libCom/fdmgr/fdmgr.cpp:29:
../../../src/libCom/osi/os/WIN32/osdTime.h:26:8: error: redefinition of 'struct timespec'
struct timespec {
In file included from ../../../src/libCom/osi/epicsTime.h:15:0,
c:\mingw\include\time.h:102:8: error: previous definition of 'struct timespec'
struct timespec
../../../configure/RULES_BUILD:218: recipe for target 'fdmgr.o' failed
make[1]: *** [fdmgr.o] Error 1
make[1]: Leaving directory 'P:/epics/epics/base-3.14.12.5/src/libCom/O.win32-x86-mingw'
../../configure/RULES_ARCHS:64: recipe for target 'install.win32-x86-mingw' failed
make: *** [install.win32-x86-mingw] Error 2
I was able to fix the problem by using the version of osdTime.h from base-3.15.4.
Also, to build areaDetector with MinGW the following change is needed in configure/os/, adding the winmm library.
-CONFIG.win32-x86-mingw.win32-x86-mingw:OP_SYS_LDLIBS = -lws2_32
+CONFIG.win32-x86-mingw.win32-x86-mingw:OP_SYS_LDLIBS = -lws2_32 –lwinmm
