Hi,sir:
Thank you for your help, but it still doesn't work and show the problem that: Illegal field value PV .
Thank you.
Look forward to your answer.
Best regards,
Jie Xu
Subject: Re: EPICS connect to PLC:Illegal field value PV ;Connection timed
To: "[email protected]" <[email protected]>
Date: Mon, 20 Jun 2016 09:35:16 +0000
"Illegal field value PV: ai-int16-1 s7plcInitRecordAi: illegal INP field type"
Judging by this, your EPICS isn't happy about "INP" field.
This is what you have now:
field (INP, "@Testsystem:0/0 'T=INT16 L=0 H=1000'")
Looking through this (http://epics.web.psi.ch/style/software/s7plc/s7plc.html) the obvious first thing to try would be to remove extra pair of single quotation marks that you have.
Change
to
field (INP, "@Testsystem:0/0 T=INT16 L=0 H=1000")
See if this helps?
______________________
Nick Levchenko
Control Systems Engineer
Integrated Control System Division
European Spallation Source ERIC
P.O Box 176, SE-221 00 Lund, Sweden
Visiting address: Tunavägen 24, Lund
Mobile: +46 721 79 23 64
Phone: +46 46 888 33 64
E-mail: [email protected]
www.esss.se
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: 18 June 2016 19:00
To: [email protected]
Subject: Tech-talk Digest, Vol 10, Issue 239
Send Tech-talk mailing list submissions to
[email protected]
To subscribe or unsubscribe via the World Wide Web, visit
https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
or, via email, send a message with subject or body 'help' to
[email protected]
You can reach the person managing the list at
[email protected]
When replying, please edit your Subject line so it is more specific than "Re: Contents of Tech-talk digest..."
Today's Topics:
1. EPICS connect to PLC:Illegal field value PV ;Connection timed
out (XU Jie)
Message: 1
Date: Sat, 18 Jun 2016 16:12:24 +0800 (GMT+08:00)
Subject: EPICS connect to PLC:Illegal field value PV ;Connection timed
out
Message-ID: <[email protected]>
Content-Type: text/plain; charset=UTF-8
Hello sir,
I used the driver package s7plc.tgz from PSI and tried to connetct the EPICS IOCsoft and siemens PLC317-2PN/DP with TCP protocol. When the IOC starts, the problems like these followed:
Illegal field value PV: ai-int16-1 s7plcGetInIntInfo: uninitialized record
s7plcReceiveThread Testsystem:0: read error after 0 of 10 bytes: Connection timed out
Is the cause of the problems the ioc failed to connect with PLC? Or there are other reasons?
Thank you.
Best regards,
Jie Xu
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocfirstIocboot")
epicsEnvSet("TOP","/home/newuser/EPICS/base-3.16.0.1/support")
epicsEnvSet("EPICS_BASE","/home/newuser/EPICS/base-3.16.0.1")
cd "/home/newuser/EPICS/base-3.16.0.1/support"
dbLoadDatabase "dbd/firstIoc.dbd"
firstIoc_registerRecordDeviceDriver pdbbase var s7plcDebug 1
s7plcConfigure Testsystem:0,192.168.10.152,102,10,10,1,2000,500
dbLoadRecords db/first.db
iocInit
Starting iocInit
## EPICS R3.16.0.1 $Date: Thu 2016-03-03 17:36:43 -0600$ ## EPICS Base built Jun 7 2016 ############################################################################
s7plcInit: starting main thread
s7plcMain: main thread started
s7plcMain Testsystem:0: Connect to 192.168.10.152:102 on socket 5 s7plcEstablishConnection Testsystem:0: fd=5, IP=192.168.10.152 port=102 Illegal field value PV: ai-int16-1 s7plcInitRecordAi: illegal INP field type
s7plcMain Testsystem:0: starting send thread Testsystem:0S s7plcMain Testsystem:0: starting recv thread Testsystem:0R s7plcSendThread Testsystem:0: started s7plcReceiveThread Testsystem:0: started
## Start any sequence programs
#seq sncxxx,"user=newuser"
epics> s7plcWaitForInput Testsystem:0: select(5, 2.000000 sec) timed out
first.db
record (ai, "ai-int16-1") {
# map range 0 ... 1000 to 0.0000 ... 10.0000
field (DTYP, "S7plc")
field (EGUF, "10")
field (LOPR, "-10")
field (HOPR, "10")
field (LINR, "LINEAR")
field (PREC, "2")
field (SCAN, "I/O Intr")
Xu Jie,
Southwestern Institute of Physics
Chengdu, Sichuan 610041
China
Email: [email protected]
Tel: +86-28-8285-0326
Tech-talk mailing list [email protected] https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
End of Tech-talk Digest, Vol 10, Issue 239
Re: streams drivers Hu, Yong
ETHERCAT-4-3 on linux-arm yann
<2016>
Re: EPICS connect to PLC:Illegal field value PV ;Connection timed Nick Levchenko
asyn port driver written in Python Wang Xiaoqiang (PSI)
<2016>
