Subject: |
EPICS connect to PLC:Illegal field value PV ;Connection timed out |
"XU Jie" <[email protected]> |
To: |
[email protected] |
Date: |
Sat, 18 Jun 2016 16:12:24 +0800 (GMT+08:00) |
Hello sir,
I used the driver package s7plc.tgz from PSI and tried to connetct the EPICS IOCsoft and siemens PLC317-2PN/DP with TCP protocol. When the IOC starts, the problems like these followed:
Illegal field value PV: ai-int16-1 s7plcInitRecordAi: illegal INP field type
Illegal field value PV: ai-int16-1 s7plcGetInIntInfo: uninitialized record
s7plcReceiveThread Testsystem:0: read error after 0 of 10 bytes: Connection timed out
Is the cause of the problems the ioc failed to connect with PLC? Or there are other reasons?
Thank you.
Look forward to your answer.
Best regards,
Jie Xu
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocfirstIocboot")
epicsEnvSet("TOP","/home/newuser/EPICS/base-3.16.0.1/support")
epicsEnvSet("EPICS_BASE","/home/newuser/EPICS/base-3.16.0.1")
cd "/home/newuser/EPICS/base-3.16.0.1/support"
dbLoadDatabase "dbd/firstIoc.dbd"
firstIoc_registerRecordDeviceDriver pdbbase
var s7plcDebug 1
s7plcConfigure Testsystem:0,192.168.10.152,102,10,10,1,2000,500
dbLoadRecords db/first.db
iocInit
Starting iocInit
## EPICS R3.16.0.1 $Date: Thu 2016-03-03 17:36:43 -0600$
## EPICS Base built Jun 7 2016
s7plcInit: starting main thread
s7plcMain: main thread started
s7plcMain Testsystem:0: Connect to 192.168.10.152:102 on socket 5
s7plcEstablishConnection Testsystem:0: fd=5, IP=192.168.10.152 port=102
s7plcMain Testsystem:0: starting send thread Testsystem:0S
s7plcMain Testsystem:0: starting recv thread Testsystem:0R
s7plcSendThread Testsystem:0: started
s7plcReceiveThread Testsystem:0: started
## Start any sequence programs
#seq sncxxx,"user=newuser"
epics> s7plcWaitForInput Testsystem:0: select(5, 2.000000 sec) timed out
first.db
record (ai, "ai-int16-1") {
# map range 0 ... 1000 to 0.0000 ... 10.0000
field (DTYP, "S7plc")
field (INP, "@Testsystem:0/0 'T=INT16 L=0 H=1000'")
field (EGUF, "10")
field (LOPR, "-10")
field (HOPR, "10")
field (LINR, "LINEAR")
field (PREC, "2")
field (SCAN, "I/O Intr")
Xu Jie,
Southwestern Institute of Physics
Chengdu, Sichuan 610041
China
Email: [email protected]
Tel: +86-28-8285-0326
Re: MCA under windows7 64-bit Hinko Kocevar
Caget packet structure Stephen Molloy
<2016>
<2016>
