1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: EPICS base-3.14.12.5 installation error
To: "'Alex George'" <[email protected]>, "[email protected]" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 24 Jun 2015 14:52:08 +0000
I had a strange problem with building Windows on 3.14.12.4.  In my case I was building on a remote Linux file server.  It was working fine, and then stopped working.  I don’t remember the error, but it may have been similar to what you are seeing.  I was able to solve it by simply reinstalling EPICS base.
Have you tried that on your problematic machine?  Completely remove the EPICS base installation and install it again.
From: [email protected] [mailto:[email protected]] On Behalf Of Alex George
Sent: Wednesday, June 24, 2015 9:23 AM
To: [email protected]
Cc: EPICS tech-talk
Subject: Re: EPICS base-3.14.12.5 installation error
Hi Freddie and Andrew,
I apologize for the delayed response.
Freddie:
I've actually tried that command with the same error occurring at line 28: open(INP,"$file") or die "$! opening file";
I've compiled successfully on another machine in the lab with the exact set up without any errors; more so I've attempted to hard code the file path in the line 28 $file variable to no success (hard coding worked on the successful machine).
Andrew:
- I've tried the latest versions of Strawberry Perl and ActiveState, both x64, both running into the same error.
- The permissions on both of the files are the same but as before only the one runs
Clutching straws,
Alex
On Tue, Jun 23, 2015 at 12:04 PM, <[email protected]> wrote:
Hi Andrew,
We are using Strawberry Perl 5.12.3.0
    C:\Instrument\Apps\EPICS\base\3-14-12-4\src\softIoc>perl -v
    This is perl 5, version 12, subversion 3 (v5.12.3) built for MSWin32-x64-multi-thread
The permissions on  makeIncludeDbd.pl  should be the same as those on  registerRecordDeviceDriver.pl  and his perl is able to run makeIncludeDbd.pl - maybe worth Alex just comparing them to be sure.
The filename "registerRecordDeviceDriver.pl" is longer than "makeIncludeDbd.pl " though, maybe we have hit a path length limit is that version of ActiveState perl?
When I start running "process monitor", you can tell I'm clutching straws too :-)
Freddie
-----Original Message-----
Sent: 23 June 2015 16:43
To: Akeroyd, Freddie (STFC,RAL,ISIS); [email protected]
Cc: [email protected]
Hi Freddie,
Whose version of Perl are you using? I use Strawberry Perl here, although our Jenkins build server does have the ActiveState version installed. I'm wondering if there might be something different in the way that the ActiveState Perl that Alex is using has been built, such that it doesn't understand file permissions in quite the same way.
Clutching at straws here...
- Andrew
On 06/23/2015 10:35 AM, [email protected] wrote:
> Hi,
> I have similar permissions to Alex on my installation and epics builds OK - my windows domain account is explicitly in the BUILTIN\Administrators group, but will also be in BUILTIN\Users (which include "domain users"). I'm guessing Alex is too a local administrator on his computer?
> Alex, what happens if you try and run these things outside of make:
>     cd C:\epics\base-3.14.12.5\src\softIoc\O.windows-x64
>    type ..\..\..\bin\windows-x64\registerRecordDeviceDriver.pl
>    perl ..\..\..\bin\windows-x64\registerRecordDeviceDriver.pl
>    perl ../../../bin/windows-x64/registerRecordDeviceDriver.pl
> For both perl commands you should get something like "No such file or directory opening file at ../../../bin/windows-x64-debug/registerRecordDeviceDriver.pl line 28"
> It is rather strange that your build is able to execute:
>     perl ../../../bin/windows-x64/makeIncludeDbd.pl base.dbd
> dlload.dbd system.dbd softIocInclude.dbd
> but not
> ../O.Common/softIoc.dbd softIoc_registerRecordDeviceDriver
> C:/epics/base-3.14.12.5 > softIoc.tmp
> It is possible to open files on windows and deny other processes read access even if the file permissions would otherwise grant such access. This would cause a "sharing violation", but these can get reported as "file not found" by some tools. Clutching at straws here, is there any possibility of another process/tool being involved and causing problems?
> There are useful windows diagnostic tools at https://technet.microsoft.com/en-us/sysinternals/default - i've used "handle" (to list all open files) and "process monitor" (to look at file accesses) before to diagnose problems. If you install process monitor, you can filter on something like "command line   contains   perl" and then do a make in the softioc directory. This should give some idea of what file access the perl program is trying to do, and how successful it is at this.
> Regards,
> Freddie
> [mailto:[email protected]] On Behalf Of Andrew Johnson
> Sent: 22 June 2015 20:24
> To: Alex George
> Cc: EPICS tech-talk
> On 06/22/2015 12:28 PM, Alex George wrote:
>>   cd C:/epics/base-3.14.12.5/src/softIoc
>>   icacls ../../bin/windows-x64/registerRecordDeviceDriver.pl
>> C:\epics\base-3.14.12.5\src\softIoc>icacls
>> ../../bin/windows-x64/registerRecordDeviceDriver.pl BUILTIN\Administrators:(I)(F)
>>                                                     NT AUTHORITY\SYSTEM:(I)(F)
>>                                                     BUILTIN\Users:(I)(RX)
>>                                                     NT
>> AUTHORITY\Authenticated Users:(I)(M)
>> Successfully processed 1 files; Failed processing
> None of the names listed there are obviously your user account, so I'm becoming more convinced that this problem is due to file permissions.
> When I run the same command for my build the result looks like this:
>> D:\epics\mirror-3.14\src\softIoc>icacls
>> ..\..\bin\windows-x64\registerRecordDeviceDriver.pl ANL\anj:(I)(F)
>>                                                     ANL\Domain Users:(I)(RX)
>>                                                     Everyone:(I)(RX)
>> Successfully processed 1 files; Failed processing 0 files
> I'm logged in as ANL\anj and I have full permissions (F) over that file.
> Can any Windows experts out there comment on this? I don't really understand the intricacies of the Windows permissions system or how ActiveState Perl may be unable to execute a script which it itself installed earlier in the build process.
> Alex,
> If you can either take ownership or give yourself full permissions over the C:/epics directory tree (and all its subdirectories and files) that will probably fix the problem. You would do that by bringing up Windows Explorer and the Properties dialog for the directory, then go to the Security tab and click the Edit button.
> - Andrew
> Light thinks it travels faster than anything but it is wrong.
> No matter how fast light travels, it finds the darkness has always got there first, and is waiting for it.
>     -- Terry Pratchett, Reaper Man
Alex George
Bioengineering Student
A. James Clark School of Engineering
University of Maryland, College Park
Phone: (301) 741-0847
RE: EPICS base-3.14.12.5 installation error freddie.akeroyd
EPICS base-3.14.12.5 installation error Alex George
Re: EPICS base-3.14.12.5 installation error Johnson, Andrew N.
Re: EPICS base-3.14.12.5 installation error Andrew Johnson
Re: EPICS base-3.14.12.5 installation error Alex George
Prev: Re: EPICS base-3.14.12.5 installation error Alex George
Next: RE: UCHAR to BitArray conversion Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: EPICS base-3.14.12.5 installation error freddie.akeroyd
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
