1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS base-3.14.12.5 installation error
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 22 Jun 2015 13:28:35 -0400
  cd C:/epics/base-3.14.12.5/src/softIoc
  icacls ../../bin/windows-x64/registerRecordDeviceDriver.pl
C:\epics\base-3.14.12.5\src\softIoc>icacls ../../bin/windows-x64/registerRecordDeviceDriver.pl
../../bin/windows-x64/registerRecordDeviceDriver.pl BUILTIN\Administrators:(I)(F)
                                                    NT AUTHORITY\SYSTEM:(I)(F)
                                                    BUILTIN\Users:(I)(RX)
                                                    NT AUTHORITY\Authenticated Users:(I)(M)
Successfully processed 1 files; Failed processing
On Mon, Jun 22, 2015 at 1:08 PM, Andrew Johnson <[email protected]> wrote:
Hi Alex,
On 06/22/2015 11:48 AM, Alex George wrote:
> I was looking over the error output and it looked like some of it wasn't
> copied over in the original message:
> /make[3]: *Entering directory
> `C:/epics/base-3.14.12.5/src/softIoc/O.windows-x64'*/
Ok, that was the line I was looking for which you had omitted -- no problem.
>     /C:\epics\base-3.14.12.5\src\softIoc>make/
>     /perl ../../bin/windows-x64/makeMakefile.pl O.windows-x64 ../../../
>     /perl -MExtUtils::Command -e mkpath O.Common/
>     /make -C O.windows-x64 -f ../Makefile TOP=../../.. \/
>     /            T_A=windows-x64 install/
>     /make[1]: Entering directory
>     `C:/epics/base-3.14.12.5/src/softIoc/O.windows-x64'/
>     /perl ../../../bin/windows-x64/makeIncludeDbd.pl base.dbd dlload.dbd
>     system.dbd softIocInclude.dbd/
>     /echo "../O.Common/softIocInclude.dbd : ../Makefile" >> softIoc.dbd.d/
>     /"Expanding dbd"/
>     /"Installing created dbd file ../../../dbd/softIoc.dbd"/
>     /perl ../../../bin/windows-x64/registerRecordDeviceDriver.pl
>     ../O.Common/softIoc.dbd softIoc_registerRecordDeviceDriver
>     C:/epics/base/
>     /-3.14.12.5 > softIoc.tmp/
>     /Can't open perl script
>     "../../../bin/windows-x64/registerRecordDeviceDriver.pl": No such
>     file or directory/
>     /make[1]: *** [softIoc_registerRecordDeviceDriver.cpp] Error 2/
>     /make[1]: Leaving directory
>     /make: *** [install.windows-x64] Error 2/
Ok, it is doing the right thing then. Can you run this to display the
ACLs of that script:
>     C:\epics\base-3.14.12.5\src\softIoc>make --version
>     GNU Make 3.81
>     C:\epics\base-3.14.12.5\src\softIoc>perl -v
>     This is perl 5, version 20, subversion 2 (v5.20.2) built for
>     MSWin32-x64-multi-thread
Those look Ok.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
Alex George
Bioengineering Student
A. James Clark School of Engineering
University of Maryland, College Park
Phone: (301) 741-0847
Re: EPICS base-3.14.12.5 installation error Andrew Johnson
EPICS base-3.14.12.5 installation error Alex George
Re: EPICS base-3.14.12.5 installation error Johnson, Andrew N.
Re: EPICS base-3.14.12.5 installation error Alex George
Prev: Re: EPICS base-3.14.12.5 installation error Andrew Johnson
Next: Re: EPICS base-3.14.12.5 installation error Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
