1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Stream device problem with redirection in @mismatch
To: ruzickaj <[email protected]>
Cc: Tech Talk <[email protected]>
Date: Wed, 8 Apr 2015 11:37:11 +0200
On 08.04.2015 11:20, Dirk Zimoch wrote:
/usr/local/epics/support/stream/StreamDevice-2-6/lib/linux-x86_64/libstream.so(_ZN6Stream15getFieldAddressEPKcR12StreamBuffer+0xcd)[0x7f9c3d4bd34d]
I found the bug in getFieldAddress:
         // FIELD in this record or VAL in other record
         char fullname[PVNAME_SZ + 1];
         sprintf(fullname, "%s.%s", name(), fieldname);
         if (dbNameToAddr(fullname, &dbaddr) != OK)
             // VAL in other record
             sprintf(fullname, "%s.VAL", fieldname);
             if (dbNameToAddr(fullname, &dbaddr) != OK) return false;
The first sprintf prints
$(device):StatEnable.$(device):StatEnableInterlock which is way too
long. My fault. I will send a patch soon....
Dirk
Try this:
        StreamBuffer fullname;
        fullname.print("%s.%s", name(), fieldname);
        if (dbNameToAddr(fullname(), &dbaddr) != OK)
            fullname.clear().print("%s.VAL", fieldname);
            if (dbNameToAddr(fullname(), &dbaddr) != OK) return false;
(in src/StreamEpics.cc function getFieldAddress)
Dirk
Re: Stream device problem with redirection in @mismatch ruzickaj
Re: Stream device problem with redirection in @mismatch Michael Johnson
Re: Stream device problem with redirection in @mismatch Dirk Zimoch
Prev: Re: Stream device problem with redirection in @mismatch Dirk Zimoch
Next: StreaDevice formating problem Jörn Wüstenfeld
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Stream device problem with redirection in @mismatch ruzickaj
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
