1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Stream device problem with redirection in @mismatch
To: [email protected]
Date: Wed, 01 Apr 2015 15:51:24 +0200
Hi all,
I have a device that sends a response on command
"on/off" (requested value) or "INTERLOCK").
I use a @mismatch exception handler and redirection to record in
order to catch this "INTERLOCK" string. After that I turn on or off the LED widget (Interlocked or Non-Interlocked). When I started IOC it gave me a buffer overflow.
Buffer overflow is appeared after adding arg: (\$2).
DB and proto file are following:
DB:
# requested value laser state
record(bi, "$(device):StatEnable")
    field(DESC, "Laser Enabled")
    field(DTYP, "stream")
field(INP, "@fibotecLtbis.proto get_enable($(channel),$(device):StatEnableInterlock) $(port)")
    field(SCAN, "1 second")
    field(ZNAM, "Off")
    field(ONAM, "On")
    field(PINI,"YES")
#makro
#channel=1
#device=name:ch1
#Catching INTERLOCK message
record(bi, "$(device):StatEnableInterlock")
    field(ZNAM, "INTERLOCK")
    field(ONAM, "Ok")
    field(VAL, "1")
    field(PINI,"YES")
Proto file:
get_enable { out "get ch\$1 status"; in "get ch\$1 status\r\r\n = %{off|on } ";
@mismatch {in "get ch\$1 status\r\r\n%(\$2){INTERLOCK}";}}
Thanks Jan
RE: Stream device problem with redirection in @mismatch Mazanec Tomáš
Re: Stream device problem with redirection in @mismatch Dirk Zimoch
Prev: Fwd: EPICSv4 and pvAccess to an IOC White, Greg
Next: EPICS UIs in the context of changing enum record identifiers Jameson Graef Rollins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: STAT=SCAN recover Mark Rivers
Next: RE: Stream device problem with redirection in @mismatch Mazanec Tomáš
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
