1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Stream device problem with redirection in @mismatch
To: <[email protected]>
Date: Thu, 2 Apr 2015 16:10:43 +0200
Hello Jan,
What is your terminator?
I tried to reproduce your problem but everything seems to work.
BTW: There are some other ways:
1. Use 3-state mbbi and %{off|on |INTERLOCK} format.
2. Use default value assignment (relatively new feature):
%?... does not fail on mismatch but results in 0. (or "" for string formats).
 in "get ch\$1 status\r\r\n = %?{off|on }%(\$2){INTERLOCK|}";
If the device sends "INTERLOCK", %?{off|on } results in 0 (Off) and %(\$2){INTERLOCK|} in 1 (INTERLOCK)
If the device sends "off" or "on ", %(\$2){INTERLOCK|} results in 1 (Ok).
Dirk
On 01.04.2015 15:51, ruzickaj wrote:
Hi all,
I have a device that sends a response on command
"on/off" (requested value) or "INTERLOCK").
I use a @mismatch exception handler and redirection to record in
order to catch this "INTERLOCK" string. After that I turn on or off the
LED widget
(Interlocked or Non-Interlocked). When I started IOC it gave me a buffer
overflow.
Buffer overflow is appeared after adding arg: (\$2).
DB and proto file are following:
DB:
# requested value laser state
record(bi, "$(device):StatEnable")
     field(DESC, "Laser Enabled")
     field(DTYP, "stream")
     field(INP,  "@fibotecLtbis.proto
get_enable($(channel),$(device):StatEnableInterlock) $(port)")
     field(SCAN, "1 second")
     field(ZNAM, "Off")
     field(ONAM, "On")
     field(PINI,"YES")
#makro
#channel=1
#device=name:ch1
#Catching INTERLOCK message
record(bi, "$(device):StatEnableInterlock")
     field(ZNAM, "INTERLOCK")
     field(ONAM, "Ok")
     field(VAL, "1")
     field(PINI,"YES")
Proto file:
get_enable  { out "get ch\$1 status"; in "get ch\$1 status\r\r\n =
%{off|on } ";
@mismatch {in "get ch\$1 status\r\r\n%(\$2){INTERLOCK}";}}
Thanks Jan
Re: Stream device problem with redirection in @mismatch ruzickaj
Prev: Re: Stream device: how to send waveform of chars without null terminator? Isabella Rey
Next: Re: Stream device: how to send waveform of chars without null terminator? Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Stream device problem with redirection in @mismatch ruzickaj
Next: Re: Stream device problem with redirection in @mismatch ruzickaj
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
