On Wed, Feb 11, 2015 at 02:28:39PM +0100, Dirk Zimoch wrote:
> On 09.02.2015 21:58, Kasemir, Kay wrote:
>> and then you need to be prepared to parse a response that looks like
>> HTTP/1.1 200 OK
>> Content-Type: text/html
>> Server: Whatever
>> Cache-Control: no-cache
>> Pragma: no-cache
>> Content-Length: 97
>> .. the actual data..
> Try regular expressions to fund the actual data in all the http noise.
> See my example in the StreamDevice documentation:
> http://epics.web.psi.ch/software/streamdevice/doc/tipsandtricks.html#web
> get_title {
> extrainput = ignore;
> replyTimeout = 1000;
> out "GET http://\$1\n\n";
> in "%+.1/(?im)<title>(.*)<\/title>/";
Something like this can work with a device that always responds in a fixed
pattern. However, you should be aware that, in general, regular expressions
cannot be used to parse arbitrary HTML. A Stack Overflow article that
talks about this can be found here:
http://stackoverflow.com/questions/6751105/why-its-not-possible-to-use-regex-to-parse-html-xml-a-formal-explanation-in-la
A more entertaining, though less illuminating, explanation can be found here:
http://stackoverflow.com/questions/1732348/regex-match-open-tags-except-xhtml-self-contained-tags/1732454#1732454
Hope this helps.
Bill Lavender
- Re: using EPICS code with HTTP port Dirk Zimoch
- using EPICS code with HTTP port Ana Malagon
- RE: using EPICS code with HTTP port Mark Rivers
- Re: using EPICS code with HTTP port Kasemir, Kay
Re: Multiple IOCs on single non-networked host Re: can run multiple IOCs on single host? J. Lewis Muir
EPICS Collaboration Meeting May 2014 Hoff, Larry
<2015>
<2015>
