1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Multiple IOCs on single non-networked host Re: can run multiple IOCs on single host?
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 11 Feb 2015 11:43:10 -0600
On 2/11/15 8:06 AM, Kasemir, Kay wrote:
> The situation is different when the host is not connected to a real
> network, so all you have is "localhost" and no broadcast address.
For running locally, I just use the IPv4 address of the loopback
interface (127.0.0.1 in my case) by setting the following environment
variables (shown for a Bourne shell):
$ export EPICS_CA_AUTO_ADDR_LIST=NO
$ export EPICS_CA_ADDR_LIST=127.0.0.1
$ export EPICS_CAS_INTF_ADDR_LIST=127.0.0.1
$ export EPICS_CAS_BEACON_ADDR_LIST=127.0.0.1
This works for me.
(I actually also set EPICS_CA_REPEATER_INTF_ADDR_LIST=127.0.0.1, but
this is *not* part of EPICS Base; I patched my EPICS Base to use it
so that caRepeater would bind to the interface I wanted--the loopback
interface in this case.)
> As Ralph mentions, sometimes it works and sometimes it doesn't.
This could be due to the fact that broadcast support on the loopback
network seems to vary by platform.  For example, on OS X Yosemite
(10.10.2), broadcast on the loopback interface does not seem to work,
but on Ubuntu 12.04.5 LTS (3.13 kernel) it does.
Here's the test I used:
1. In two separate terminals run the following:
   $ nc -u -l 1234
2. In a third terminal run the following:
   $ echo TEST | socat - udp-datagram:127.255.255.255:1234,broadcast
On OS X Yosemite, nothing gets printed to the first two terminals, but
on Ubuntu 12.04.5 LTS, the first two terminals print "TEST".
> In addition, there seems to be some remaining difference between the
> C implementation of the channel access client library and the pure
> Java CAJ implementation.
What are these?  I would love to get them straightened out if possible!
Lewis
can run multiple IOCs on single host? JaeRyong Seo
Re: can run multiple IOCs on single host? Dirk Zimoch
Re: can run multiple IOCs on single host? Ralph Lange
Multiple IOCs on single non-networked host Re: can run multiple IOCs on single host? Kasemir, Kay
Prev: Re: multiple overlays with NDPluginOverlay David Michel
Next: Re: using EPICS code with HTTP port Bill Lavender
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Multiple IOCs on single non-networked host Re: can run multiple IOCs on single host? J. Lewis Muir
Next: Re: can run multiple IOCs on single host? JaeRyong Seo
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
