1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: using EPICS code with HTTP port
To: <[email protected]>
Date: Thu, 12 Feb 2015 12:07:34 +0100
On 11.02.2015 18:45, Bill Lavender wrote:
On Wed, Feb 11, 2015 at 02:28:39PM +0100, Dirk Zimoch wrote:
On 09.02.2015 21:58, Kasemir, Kay wrote:
and then you need to be prepared to parse a response that looks like
HTTP/1.1 200 OK
Content-Type: text/html
Server: Whatever
Cache-Control: no-cache
Pragma: no-cache
Content-Length: 97
.. the actual data..
Try regular expressions to fund the actual data in all the http noise.
See my example in the StreamDevice documentation:
http://epics.web.psi.ch/software/streamdevice/doc/tipsandtricks.html#web
get_title {
   extrainput = ignore;
   replyTimeout = 1000;
   out "GET http://\$1\n\n";;
   in "%+.1/(?im)<title>(.*)<\/title>/";
Something like this can work with a device that always responds in a fixed
pattern.  However, you should be aware that, in general, regular expressions
cannot be used to parse arbitrary HTML.  A Stack Overflow article that
talks about this can be found here:
     http://stackoverflow.com/questions/6751105/why-its-not-possible-to-use-regex-to-parse-html-xml-a-formal-explanation-in-la
A more entertaining, though less illuminating, explanation can be found here:
     http://stackoverflow.com/questions/1732348/regex-match-open-tags-except-xhtml-self-contained-tags/1732454#1732454
Hope this helps.
Bill Lavender
Bill is right. I also mention this in my documentation:
"But this only works if the order of the values is predictible. StreamDevice is not an XML parser! It always reads sequentially."
The web page must have a fixed format. In particular all values to parse must always be in the same order.
Dirk
using EPICS code with HTTP port Ana Malagon
RE: using EPICS code with HTTP port Mark Rivers
Re: using EPICS code with HTTP port Kasemir, Kay
Re: using EPICS code with HTTP port Dirk Zimoch
Re: using EPICS code with HTTP port Bill Lavender
Prev: Re: EPICS Collaboration Meeting May 2014 Torsten Bögershausen
Next: RE: EPICS Collaboration Meeting May 2014 Hoff, Larry
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: using EPICS code with HTTP port Bill Lavender
Next: Re: using EPICS code with HTTP port Ana Malagon
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
