1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: setting interpreter in EPICS
Date: Mon, 26 Jan 2015 11:16:18 -0800
I'm using an external library in EPICs application; this library requires a newer compiler version than I have on my system (needs glibc 2.15 to run but my Debian system has 2.13). Long story short, I have installed the newer compiler in a separate folder, but now need to figure out how to invoke this compiler when building the IOC.
I've been following the instructions here to update my compiler and they suggest using a program called patchelf to set the interpreter correctly for programs. I'm not sure how this would translate to EPICS, as there is no executable - does anyone have experience using different versions of glibc with EPICS and know what I should do in this case?
Thanks very much,
Ana
RE: setting interpreter in EPICS Mark Rivers
Prev: Re: Using asynDriver outside of an EPICS IOC Andrew Johnson
Next: Re: Alarm annunciation with ALH and other PC based systems Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Checking which record triggered processing Mooney, Tim M.
Next: RE: setting interpreter in EPICS Mark Rivers
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
