1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Checking which record triggered processing
To: Tobiasz Czopowicz <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 26 Jan 2015 16:05:36 +0000
Yes,
B can read A.PACT.  It will be true if A is causing B to process via a PP link.  (This won't work with a CA link, though.)
By the way, it doesn't matter if the field A writes to via a PP link has "pp(TRUE)" in the .dbd file; the PP link causes B to process in any case.
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Tobiasz Czopowicz [[email protected]]
Sent: Monday, January 26, 2015 8:15 AM
To: [email protected]
Subject: Checking which record triggered processing
Dear All,
say I have two records, A and B. And A writes something into B causing
it to process itself (one of the fields with pp(TRUE) in .dbd file).
Is there a way that B "knows" that it was A that triggered processing?
Tobiasz Czopowicz
Checking which record triggered processing Tobiasz Czopowicz
Prev: Re: sequencer release 2.2.1 Paul Hamadyk
Next: RE: Alarm annunciation with ALH and other PC based systems Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Checking which record triggered processing Tobiasz Czopowicz
Next: setting interpreter in EPICS Ana Malagon
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
