1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Alarm annunciation with ALH and other PC based systems
To: Emmanuel Mayssat <[email protected]>, EPICS mailing list <[email protected]>
Date: Mon, 26 Jan 2015 09:20:27 -1000
On 01/26/15 08:27, Emmanuel Mayssat wrote:
The ALH indeed works well.
But I am not sure this is the most reliable solution for 3 reasons.
1/ The ALH runs on the client PC
2/ The ALH runs on PC hardware.
any hardware can fail, that aside:
3/ The ALH can be turned off by operators. (speakers can simply be
turned off to make the alarm system fail)
the depends on how you 'broadcast' the alarms. We run ours on headless
machines, and they send email (and in at least one case text messages).
So, while the operators my be able to kill the processes, depending
on whether you let them, just turning off speakers wouldn't do anything
here.
Maren
Alarm annunciation with ALH and other PC based systems Rod Nussbaumer
RE: Alarm annunciation with ALH and other PC based systems Emmanuel Mayssat
Re: Alarm annunciation with ALH and other PC based systems Maren Purves
Prev: setting interpreter in EPICS Ana Malagon
Next: Re: Problem building epics base under CentOS 5.6 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Alarm annunciation with ALH and other PC based systems Emmanuel Mayssat
Next: RE: Alarm annunciation with ALH and other PC based systems Elder Matias
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
