The ALH indeed works well.
But I am not sure this is the most reliable solution for 3 reasons.
1/ The ALH runs on the client PC
2/ The ALH runs on PC hardware.
3/ The ALH can be turned off by operators. (speakers can simply be turned off to make the alarm system fail)
To solve this without the ALH, you need to run a back-end service (i.e. on the server side) that filters and dispatches the alarms to dedicated hardware.
This is already implemented in BEAST, the CSS alarm handler.
A similar architecture is intended to be used for the one part of EPICS Qt.
Emmanuel Mayssat
http://www.epicsqt.org
> Date: Tue, 20 Jan 2015 13:59:32 -1000
> From:
[email protected]> To:
[email protected]> Subject: Re: Alarm annunciation with ALH and other PC based systems
> ALH or something else, sensors can fail too, it doesn't have to
> have anything to do with what you're running or what you're
> running it on. We recently had an almost whole system shutdown
> (thankfully the instruments stayed cold) when the UPS failed
> to last through a power outage.
> The old ALH works quite well :)
> Maren
