1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Problem building epics base under CentOS 5.6
To: [email protected]
Date: Sat, 24 Jan 2015 11:57:13 +0800 (GMT+08:00)
Hello,
     I am a beginner of linux, as well as to the EPICS.
     I run into an error when I build EPICS base-3.14.12 on a 32-bit laptop with CentOS 5.6.
     Can anyone help in this
   error code:
In file included from ../../../src/libCom/cxxTemplates/resourceLib.cpp:22:
../../../src/libCom/cxxTemplates/resourceLib.h:33:15: warning: new: No such file or directory
../../../src/libCom/cxxTemplates/resourceLib.h:34:20: warning: typeinfo: No such file or directory
../../../src/libCom/cxxTemplates/resourceLib.h: In member function ‘void resTable<T, ID>::show(unsigned int) const’:
../../../src/libCom/cxxTemplates/resourceLib.h:378: error: must #include <typeinfo> before using typeid
make[3]: *** [resourceLib.o] Error 1
make[3]: Leaving directory `/home/gongyu/EPICS/base-3.14.12/src/libCom/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/home/gongyu/EPICS/base-3.14.12/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/home/gongyu/EPICS/base-3.14.12/src'
make: *** [src.install] Error 2
How can I do for this error?
Gongyu
Re: Problem building epics base under CentOS 5.6 Andrew Johnson
Prev: Re: EPICS driver for CAENels HV-Adaptos? Weiwei Lu
Next: Re: sequencer release 2.2.1 Paul Hamadyk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Using asynDriver outside of an EPICS IOC Mark Rivers
Next: Re: Problem building epics base under CentOS 5.6 Andrew Johnson
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
