On 01/23/2015 09:57 PM, GONG Yu wrote:
> I run into an error when I build EPICS base-3.14.12 on a 32-bit laptop with CentOS 5.6.
> Can anyone help in this error code:
> In file included from ../../../src/libCom/cxxTemplates/resourceLib.cpp:22:
> ../../../src/libCom/cxxTemplates/resourceLib.h:33:15: warning: new: No such file or directory
> ../../../src/libCom/cxxTemplates/resourceLib.h:34:20: warning: typeinfo: No such file or directory
> ../../../src/libCom/cxxTemplates/resourceLib.h: In member function ‘void resTable<T, ID>::show(unsigned int) const’:
> ../../../src/libCom/cxxTemplates/resourceLib.h:378: error: must #include <typeinfo> before using typeid
The first two errors here imply that your C++ installation does not have
the standard C++ library headers new or typeinfo installed, and the last
error tells me that the compiler expects those headers to be available.
I don't have access to a CenOS 5.6 system so I don't know for sure that
this will work, but I think you should be able to install those headers
by running
yum install libstdc++-devel
as root (or using sudo).
I would recommend that you install the latest version (base-3.14.12.4)
instead though, it has a number of bug fixes included.
- Andrew
Doctorow's Law: Anytime someone puts a lock on something you own,
against your wishes, and doesn't give you the key, they're
not doing it for your benefit.
- Re: Re: Problem building epics base under CentOS 5.6 GONG Yu
- Problem building epics base under CentOS 5.6 GONG Yu
Re: Alarm annunciation with ALH and other PC based systems Maren Purves
RE: Using asynDriver outside of an EPICS IOC Mark Rivers
<2015>
<2015>
