Marc,
thank you for your quick answer.
I am running base-3.15.1-rc1
areaDetector just downloaded today from the git-master, so I assume R2-1
with
ADCore also downloaded today is R2-2
h1@earth:~/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC$ pwd
/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC
h1@earth:~/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC$ make
clean uninstall
make -C ./configure clean
make[1]: Entering directory
`/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/configure'
rm -rf O.linux-x86_64 O.Common
make[1]: Leaving directory
make -C ./simDetectorApp clean
`/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp'
make -C ./Db clean
make[2]: Entering directory
`/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/Db'
make[2]: Leaving directory
make -C ./src clean
`/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src'
make -C ./iocBoot clean
`/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/iocBoot'
make -C ./iocSimDetector clean
`/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/iocBoot/iocSimDetector'
rm -f cdCommands envPaths dllPath.bat relPaths.sh
rm -rf ./bin/linux-x86_64
rm -rf ./lib/linux-x86_64
`/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC'
rm -rf ./bin
rm -rf ./lib
rm -rf ./dbd ./include ./doc ./html ./templates ./db ./adl ./alh ./cfg
./edl ./lib/perl ./lib/pkgconfig
make -C ./configure install
perl -CSD /home/h1/EPICS/base/bin/linux-x86_64/makeMakefile.pl
O.linux-x86_64 ../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install
`/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/configure/O.linux-x86_64'
perl -CSD /home/h1/EPICS/base/bin/linux-x86_64/convertRelease.pl
checkRelease
make -C ./simDetectorApp install
make -C ./Db install
O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[3]: Entering directory
`/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/Db/O.linux-x86_64'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory
make -C ./src install
mkdir O.Common
`/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src/O.linux-x86_64'
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_
-DUNIX -Dlinux -O3 -g -Wall -m64 -I. -I../O.Common -I.
-I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux
-I../../../include -I/home/h1/EPICS/base/include/compiler/gcc
-I/home/h1/EPICS/base/include/os/Linux -I/home/h1/EPICS/base/include
-I/home/h1/EPICS/support/asyn4-25/include
-I/home/h1/EPICS/support/areaDetector/ADCore/include
-I/home/h1/EPICS/support/calc-3-4/include
-I/home/h1/EPICS/support/busy-1-6-1/include
-I/home/h1/EPICS/support/sscan-2-10/include
-I/home/h1/EPICS/support/autosave-5-5/include/os/Linux
-I/home/h1/EPICS/support/autosave-5-5/include -MM -MF
simDetectorAppMain.d ../simDetectorAppMain.cpp
Creating dbd file simDetectorApp.dbd
perl -CSD /home/h1/EPICS/base/bin/linux-x86_64/dbdExpand.pl -I. -I..
-I../O.Common -I../../../dbd -I/home/h1/EPICS/base/dbd
-I/home/h1/EPICS/support/asyn4-25/dbd
-I/home/h1/EPICS/support/areaDetector/ADCore/dbd
-I/home/h1/EPICS/support/calc-3-4/dbd
-I/home/h1/EPICS/support/busy-1-6-1/dbd
-I/home/h1/EPICS/support/sscan-2-10/dbd
-I/home/h1/EPICS/support/autosave-5-5/dbd -o simDetectorApp.dbd
simDetectorSupport.dbd commonDriverSupport.dbd
dbdExpand.pl: Leaving context "file
'/home/h1/EPICS/support/areaDetector/ADCore/dbd/commonDriverSupport.dbd'",
found "file
'/home/h1/EPICS/support/areaDetector/ADCore/dbd/NDPluginSupport.dbd'"
instead.
Braces must be closed in the same file they open in.
Context: file
while reading 'commonDriverSupport.dbd' to create 'simDetectorApp.dbd'
dbdExpand.pl: Exiting due to errors
found "file
instead.
Context: file
'../O.Common/simDetectorApp.dbd.d'
found "file
instead.
Context: file
make[3]: *** [../O.Common/simDetectorApp.dbd] Error 255
make[2]: *** [install.linux-x86_64] Error 2
make[1]: *** [src.install] Error 2
make: *** [simDetectorApp.install] Error 2
On 09.01.2015 16:16, Mark Rivers wrote:
I have never encountered this error. What version of areaDetector and what version of EPICS base are you using?
This is the command that was executing for you when building for linux-x86_64 in that directory:
make[6]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src/O.linux-x86_64'
perl -CSD /home/h1/EPICS/base/bin/linux-x86_64/dbdExpand.pl -I. -I.. -I../O.Common -I../../../dbd -I/home/h1/EPICS/base/dbd -I/home/h1/EPICS/support/asyn4-25/dbd -I/home/h1/EPICS/support/areaDetector/ADCore/dbd -I/home/h1/EPICS/support/calc-3-4/dbd -I/home/h1/EPICS/support/busy-1-6-1/dbd -I/home/h1/EPICS/support/sscan-2-10/dbd -I/home/h1/EPICS/support/autosave-5-5/dbd -o simDetectorApp.dbd simDetectorSupport.dbd commonDriverSupport.dbd
This is the command that was executing for me:
make[3]: Entering directory `/home/epics/devel/areaDetector-2-1/ADCore/iocs/simDetectorIOC/simDetectorApp/src/O.linux-x86_64'
perl /corvette/usr/local/epics/base-3.14.12.4/bin/linux-x86_64/makeIncludeDbd.pl simDetectorSupport.dbd commonDriverSupport.dbd simDetectorAppInclude.dbd
echo "../O.Common/simDetectorAppInclude.dbd : ../Makefile" >> simDetectorApp.dbd.d
Expanding dbd
Installing created dbd file ../../../dbd/simDetectorApp.dbd
Note that your perl command has a "-CSD" flag and yours is executing "dbdExpand.pl" while mine is executing "makeIncludeDbd.pl". I am running ADCore R2-2 pre-release (but basically the same as R2-1) and EPICS base 3.14.12.4. Just before I ran "make" I ran "make clean uninstall" in the simDetectorIOC directory.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Heinz Junkes
Sent: Friday, January 09, 2015 8:58 AM
To: [email protected] ([email protected])
Subject: areadetector dbExpand.pl error: Braces must be closed in the same file they open in.
running into following trouble:
make[5]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src'
dbdExpand.pl: Leaving context "file '/home/h1/EPICS/support/areaDetector/ADCore/dbd/commonDriverSupport.dbd'", found "file '/home/h1/EPICS/support/areaDetector/ADCore/dbd/NDPluginSupport.dbd'" instead.
Context: file '/home/h1/EPICS/support/areaDetector/ADCore/dbd/commonDriverSupport.dbd'
make[6]: *** [../O.Common/simDetectorApp.dbd] Error 255
make[6]: Leaving directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src/O.linux-x86_64'
make[5]: *** [install.linux-x86_64] Error 2
make[5]: Leaving directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src'
make[4]: *** [src.install] Error 2
and don't know how to fix it ;-)
Where should I look? Which file may really cause the error?
Cheers,
Heinz
- RE: areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Mark Rivers
- areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Heinz Junkes
<2015>
<2015>
