1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: areadetector dbExpand.pl error: Braces must be closed in the same file they open in.
To: "'Heinz P. Junkes'" <[email protected]>, "[email protected] ([email protected])" <[email protected]>
Date: Fri, 9 Jan 2015 16:16:49 +0000
Hi Heinz,
I just tried building the latest version of ADCore with the latest version of EPICS base 3.15 (using bzr to update) and got the same error as you:
Creating dbd file simDetectorApp.dbd
perl -CSD /corvette/usr/local/epics/base-3.15.0/bin/linux-x86_64/dbdExpand.pl  -I. -I.. -I../O.Common -I../../../dbd -I/corvette/usr/local/epics/base-3.15.0/dbd -I/corvette/home/epics/devel-3.15/asyn-4-25/dbd -I/corvette/home/epics/devel-3.15/areaDetector-2-1/ADCore/dbd -I/corvette/home/epics/devel-3.15/calc-3-4-1/dbd -I/corvette/home/epics/devel-3.15/busy-1-6/dbd -I/corvette/home/epics/devel-3.15/sscan-2-10/dbd -I/corvette/home/epics/devel-3.15/autosave-5-4-2/dbd -o simDetectorApp.dbd simDetectorSupport.dbd commonDriverSupport.dbd
dbdExpand.pl: Leaving context "file '/corvette/home/epics/devel-3.15/areaDetector-2-1/ADCore/dbd/commonDriverSupport.dbd'", found "file '/corvette/home/epics/devel-3.15/areaDetector-2-1/ADCore/dbd/NDPluginSupport.dbd'" instead.
Context: file '/corvette/home/epics/devel-3.15/areaDetector-2-1/ADCore/dbd/commonDriverSupport.dbd'
  while reading 'commonDriverSupport.dbd' to create 'simDetectorApp.dbd'
dbdExpand.pl: Exiting due to errors
make[3]: *** [../O.Common/simDetectorApp.dbd] Error 255
Andrew, I don't see any braces in ADCore/ADApp/commonDriverMakefile.  Can you tell me what is causing this error in 3.15, while it builds OK in 3.14.12.4?
-----Original Message-----
Sent: Friday, January 09, 2015 9:40 AM
To: Mark Rivers; [email protected] ([email protected])
Subject: Re: areadetector dbExpand.pl error: Braces must be closed in the same file they open in.
Marc,
thank you for your quick answer.
I am running base-3.15.1-rc1
areaDetector just downloaded today from the git-master, so I assume R2-1
with
ADCore also downloaded today is R2-2
h1@earth:~/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC$ pwd
/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC
h1@earth:~/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC$ make
clean uninstall
make -C ./configure clean
make[1]: Entering directory
`/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/configure'
rm -rf O.linux-x86_64 O.Common
make[1]: Leaving directory
make -C ./simDetectorApp clean
`/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp'
make -C ./Db clean
make[2]: Entering directory
`/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/Db'
make[2]: Leaving directory
make -C ./src clean
`/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src'
make -C ./iocBoot clean
`/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/iocBoot'
make -C ./iocSimDetector clean
`/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/iocBoot/iocSimDetector'
rm -f cdCommands envPaths dllPath.bat relPaths.sh
rm -rf ./bin/linux-x86_64
rm -rf ./lib/linux-x86_64
`/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC'
rm -rf ./bin
rm -rf ./lib
rm -rf ./dbd ./include ./doc ./html ./templates ./db ./adl ./alh ./cfg
./edl ./lib/perl ./lib/pkgconfig
make -C ./configure install
perl -CSD /home/h1/EPICS/base/bin/linux-x86_64/makeMakefile.pl
O.linux-x86_64 ../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install
`/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/configure/O.linux-x86_64'
perl -CSD /home/h1/EPICS/base/bin/linux-x86_64/convertRelease.pl
checkRelease
make -C ./simDetectorApp install
make -C ./Db install
O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[3]: Entering directory
`/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/Db/O.linux-x86_64'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory
make -C ./src install
mkdir O.Common
`/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_
-DUNIX  -Dlinux     -O3 -g   -Wall      -m64      -I. -I../O.Common -I.
-I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux
-I../../../include -I/home/h1/EPICS/base/include/compiler/gcc
-I/home/h1/EPICS/base/include/os/Linux -I/home/h1/EPICS/base/include
-I/home/h1/EPICS/support/asyn4-25/include
-I/home/h1/EPICS/support/areaDetector/ADCore/include
-I/home/h1/EPICS/support/calc-3-4/include
-I/home/h1/EPICS/support/busy-1-6-1/include
-I/home/h1/EPICS/support/sscan-2-10/include
-I/home/h1/EPICS/support/autosave-5-5/include/os/Linux
-I/home/h1/EPICS/support/autosave-5-5/include       -MM -MF
simDetectorAppMain.d  ../simDetectorAppMain.cpp
perl -CSD /home/h1/EPICS/base/bin/linux-x86_64/dbdExpand.pl  -I. -I..
-I../O.Common -I../../../dbd -I/home/h1/EPICS/base/dbd
-I/home/h1/EPICS/support/asyn4-25/dbd
-I/home/h1/EPICS/support/areaDetector/ADCore/dbd
-I/home/h1/EPICS/support/calc-3-4/dbd
-I/home/h1/EPICS/support/busy-1-6-1/dbd
-I/home/h1/EPICS/support/sscan-2-10/dbd
-I/home/h1/EPICS/support/autosave-5-5/dbd -o simDetectorApp.dbd
'/home/h1/EPICS/support/areaDetector/ADCore/dbd/commonDriverSupport.dbd'",
found "file
'/home/h1/EPICS/support/areaDetector/ADCore/dbd/NDPluginSupport.dbd'"
instead.
Context: file
found "file
instead.
Context: file
'../O.Common/simDetectorApp.dbd.d'
found "file
instead.
Context: file
make[2]: *** [install.linux-x86_64] Error 2
make[1]: *** [src.install] Error 2
make: *** [simDetectorApp.install] Error 2
On 09.01.2015 16:16, Mark Rivers wrote:
> I have never encountered this error.  What version of areaDetector and what version of EPICS base are you using?
> This is the command that was executing for you when building for linux-x86_64 in that directory:
> make[6]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src/O.linux-x86_64'
> perl -CSD /home/h1/EPICS/base/bin/linux-x86_64/dbdExpand.pl  -I. -I.. -I../O.Common -I../../../dbd -I/home/h1/EPICS/base/dbd -I/home/h1/EPICS/support/asyn4-25/dbd -I/home/h1/EPICS/support/areaDetector/ADCore/dbd -I/home/h1/EPICS/support/calc-3-4/dbd -I/home/h1/EPICS/support/busy-1-6-1/dbd -I/home/h1/EPICS/support/sscan-2-10/dbd -I/home/h1/EPICS/support/autosave-5-5/dbd -o simDetectorApp.dbd simDetectorSupport.dbd commonDriverSupport.dbd
> This is the command that was executing for me:
> make[3]: Entering directory `/home/epics/devel/areaDetector-2-1/ADCore/iocs/simDetectorIOC/simDetectorApp/src/O.linux-x86_64'
> perl /corvette/usr/local/epics/base-3.14.12.4/bin/linux-x86_64/makeIncludeDbd.pl simDetectorSupport.dbd commonDriverSupport.dbd simDetectorAppInclude.dbd
> echo "../O.Common/simDetectorAppInclude.dbd : ../Makefile" >> simDetectorApp.dbd.d
> Expanding dbd
> Installing created dbd file ../../../dbd/simDetectorApp.dbd
> Note that your perl command has a "-CSD" flag and yours is executing "dbdExpand.pl" while mine is executing "makeIncludeDbd.pl".  I am running ADCore R2-2 pre-release (but basically the same as R2-1) and EPICS base 3.14.12.4.  Just before I ran "make" I ran "make clean uninstall" in the simDetectorIOC directory.
> Mark
> From: [email protected] [mailto:[email protected]] On Behalf Of Heinz Junkes
> Sent: Friday, January 09, 2015 8:58 AM
> To: [email protected] ([email protected])
> Subject: areadetector dbExpand.pl error: Braces must be closed in the same file they open in.
> running into following trouble:
> make[5]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src'
> dbdExpand.pl: Leaving context "file '/home/h1/EPICS/support/areaDetector/ADCore/dbd/commonDriverSupport.dbd'", found "file '/home/h1/EPICS/support/areaDetector/ADCore/dbd/NDPluginSupport.dbd'" instead.
> Context: file '/home/h1/EPICS/support/areaDetector/ADCore/dbd/commonDriverSupport.dbd'
> make[6]: *** [../O.Common/simDetectorApp.dbd] Error 255
> make[6]: Leaving directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src/O.linux-x86_64'
> make[5]: *** [install.linux-x86_64] Error 2
> make[5]: Leaving directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src'
> make[4]: *** [src.install] Error 2
> and don't know how to fix it ;-)
> Where should I look? Which file may really cause the error?
> Cheers,
> Heinz
Re: areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Andrew Johnson
areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Heinz Junkes
RE: areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Mark Rivers
Re: areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Heinz P. Junkes
Prev: Re: areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Heinz P. Junkes
Next: sequencer release 2.1.8 Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Andrew Johnson
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
