Subject: |
Re: pyepics "Virtual circuit disconnect" CA.Client.Exception |
Walter Werner <[email protected]> |
To: |
EPICS Tech Talk <[email protected]> |
Date: |
Tue, 16 Dec 2014 16:14:28 +0100 |
hi
In fact the PV class reconnects by default, i tested it just to be
sure, you both are right. In the past i had this issue that my pvs did
not reconnect, but i can not reconstruct it anymore. Maybe an older
version of base or pcaspy. Thanks, i appreciate your help.
Walter
2014-12-16 3:50 GMT+01:00 Matt Newville <[email protected]>:
> Hi Walter,
> Sorry for the delay in responding, and thanks Andrew. To be clear, a
> pyepics.PV *does* automatically create a simple connection callback, and
> PVs should definitely re-connect on re-boot of an IOC (they do for me!).
> As Andrew suggests, using epics.ca.replace_printf_handler() is probably what
> you want for redirecting or suppressing the messages sent from the CA
> library. For example,
> import epics
> def handle_messages(text):
> print(" Saw CA Message: %s\n" % text)
> epics.ca.replace_printf_handler(handle_messages)
> By default, such messages are sent to STDERR. As an alternative, you could
> redirect all messages to STDERR, by replacing sys.stderr.write with your own
> function. That wouldn't be CA-specifc, of course.
> Hope that helps,
> --Matt
- pyepics "Virtual circuit disconnect" CA.Client.Exception Walter Werner
- Re: pyepics "Virtual circuit disconnect" CA.Client.Exception Andrew Johnson
- Re: pyepics "Virtual circuit disconnect" CA.Client.Exception Walter Werner
- Re: pyepics "Virtual circuit disconnect" CA.Client.Exception Matt Newville
Re: Changing the Timeout for drvAsynSerialPort? Dirk Zimoch
RE: Is it possible for an Asyn output record to be, also, an (I/O Intr - driven) input? Mark Rivers
<2014>
<2014>
