1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: pyepics "Virtual circuit disconnect" CA.Client.Exception
To: [email protected]
Date: Mon, 15 Dec 2014 15:22:48 +0100
hi Andrew
2014-12-12 17:44 GMT+01:00 Andrew Johnson <[email protected]>:
> Hi,
> On 12/12/2014 10:28 AM, Walter Werner wrote:
>> I use pyepics for my client and want to avoid the "Virtual circuit
>> disconnect" exception from CA being printed on the standard input.
>> CA.Client.Exception...............................................
>>     Warning: "Virtual circuit disconnect"
>>     Context: "localhost:20000"
>>     Source File: ../cac.cpp line 1215
>>     Current Time: Wed Dec 10 2014 05:51:45.821307011
>> This exception accrues if the server is down.
> Do you have a connection callback handler for your PVs? If not,
> supplying one may prevent some of the disconnect messages (and permit
> your code to find out when it should stop trying to access the PV values).
Yes, i do have the connection handler. And i try to recoonect the pv
if the connection is lost. As far as i know the PV class does not
reconnect automatically. My problem was more a cosmetic nature for the
end user. It looks not very nice if some exception is printed on the
console, although i already take care of it.
> You can also redirect any/all error messages from the underlying CA
> library by providing your own printf handler. From the pyepics
> documentation for the low-level CA module:
>> epics.ca.replace_printf_handler(fcn=None)
>>   Replace the normal printf() output handler with the supplied
>>   function (defaults to sys.stderr.write())
> Note that a single message like the one you quoted above may have come
> from several calls to the printf handler routine, so don't just try to
> pop up a new dialog box every time it gets called.
that was the method i was looking for !!! The example code looks like this:
def my_printf_handler(output_str):
    pass
    #TODO write output_str to some logfile
epics.ca.replace_printf_handler(my_printf_handler)
regards
   Walter
Re: pyepics "Virtual circuit disconnect" CA.Client.Exception Andrew Johnson
Prev: RE: CA Gateway 2.0.5.0 released freddie.akeroyd
Next: Re: pyepics "Virtual circuit disconnect" CA.Client.Exception Walter Werner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: pyepics "Virtual circuit disconnect" CA.Client.Exception Walter Werner
Next: Re: pyepics "Virtual circuit disconnect" CA.Client.Exception Andrew Johnson
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
