Hi Walter,
Sorry for the delay in responding, and thanks Andrew. To be clear, a pyepics.PV *does* automatically create a simple connection callback, and PVs should definitely re-connect on re-boot of an IOC (they do for me!). As Andrew suggests, using epics.ca.replace_printf_handler() is probably what you want for redirecting or suppressing the messages sent from the CA library. For example, import epics def handle_messages(text): print(" Saw CA Message: %s\n" % text) epics.ca.replace_printf_handler(handle_messages) By default, such messages are sent to STDERR. As an alternative, you could redirect all messages to STDERR, by replacing sys.stderr.write with your own function. That wouldn't be CA-specifc, of course. Hope that helps, --Matt
- Re: pyepics "Virtual circuit disconnect" CA.Client.Exception Walter Werner
- pyepics "Virtual circuit disconnect" CA.Client.Exception Walter Werner
- Re: pyepics "Virtual circuit disconnect" CA.Client.Exception Andrew Johnson
IPAC Version 2.13 now available Andrew Johnson
Re: Changing the Timeout for drvAsynSerialPort? Dirk Zimoch
<2014>
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
