On 11/04/2014 07:17 PM, Andrew Johnson wrote:
> Hi Damiano,
> If you want to be able to run multiple independent instances of a
> sequence program, you have to flag it as re-entrant, by adding a line
> "option +r;" after the program statement for example (you can also do it
> with a command-line flag, but the option statement is simpler).
> - Andrew
> On 11/04/2014 12:11 PM, Damiano Bortolato wrote:
>> Hi,
>> I' trying to spawn a set of instances of a sequencer program from ioc
>> shell, the program is like this:
>> program myProgram
>> int myVar;
>> assign myVar to "myPv{n}";
>> monitor myVar;
>> ss mySs {
>> Different input pvs are assigned to different program instances:
>> epics> seq myProgram "n=_1"
>> epics> seq myProgram "n=_2"
>> epics> seq myProgram "n=_n"
>> The problem is that the several instances seem to interfere each other,
>> I tried to print the address of the input variable (myVar) and I noticed
>> that they share the same myVar!!!
>> I've tried to move the myVar's definition inside the state set but the
>> problem persists.
>> Is there a way to work around this problem, or must I run my sequencers
>> as stand-alone applications?
>> Thanks in advance
>> Damiano
Hi Andrew,
Yes, now it works, thank you.
- Damiano
- Sequencer: are variables shared? Damiano Bortolato
- Re: Sequencer: are variables shared? Andrew Johnson
Re: read waveform data using ca_create_subscription Bruce Hill
Re: Re: read waveform data using ca_create_subscription 吴煊
<2014>
MinGW PRODDIR_LDFLAGS Lang, Keenan C.
<2014>
