Subject: |
Re: Re: read waveform data using ca_create_subscription |
吴煊 <[email protected]> |
To: |
tech-talk <[email protected]> |
Date: |
Wed, 5 Nov 2014 09:55:41 +0800 (GMT+08:00) |
Thank Andrew, Bruce and Yong! Andrew has pointed out the mistake I made. It's really hard to find it out. It's working smoothly now. Thank you all!
Cheers,
Xuan
> -----原始邮件-----
> 发件人: "Andrew Johnson" <[email protected]>
> 发送时间: 2014年11月5日 星期三
> 收件人: "吴煊" <[email protected]>
> 抄送:
> 主题: Re: ca problem
> Hi Xuan,
> On 11/04/2014 06:05 AM, 吴煊 wrote:
> > I've post a email to tech-talk, but received no reply. I came
> > across a weird problem. That's if I create less than 41 channels,
> > the program works fine. If I create more than 42 channels, it will
> > segment fault. I suspect that is there any limitation in ca client
> > tools. Could you help me getting rid of this? Many thanks in advance.
> > The simple code and db is in the attachment.
> The problem is in your code, in both the simplified test.c that you sent
> me and your original archive.c file. This variable definition
> char chName[MAX_STRING][CH_NUM];
> does not match your code that uses it:
> sprintf(chName[index], "wf%d", index+1);
> stat=ca_create_channel(chName[index],NULL,NULL,CA_PRIORITY_DEFAULT,&pv[index].channel);
> The code using it would need to be this:
> sprintf(&chName[0][index], "wf%d", index+1);
> stat=ca_create_channel(&chName[0][index],NULL,NULL,CA_PRIORITY_DEFAULT,&pv[index].channel);
> which does not seg-fault for me, unlike your original.
> However you don't actually need to keep the channel names in memory
> after you have passed them to ca_create_channel(), so you could replace
> the lines above with these and the result also works:
> char chName[MAX_STRING];
> sprintf(chName, "wf%d", index+1);
> stat=ca_create_channel(chName,NULL,NULL,CA_PRIORITY_DEFAULT,&pv[index].channel);
> You can always get the associated channel name from the CA chid
> afterwards using ca_name(pv[index].channel).
> Hope this helps,
> - Andrew
> People everywhere confuse what they read in newspapers with news.
> -- A. J. Liebling
Re: Sequencer: are variables shared? Damiano Bortolato
catools (caget/caput/camonitor) and locale settings from the environment Goetz Pfeiffer
<2014>
Re: read waveform data using ca_create_subscription Bruce Hill
Re: Tektronix DMM 4050 device support Hovanes Egiyan
<2014>
