Hi Damiano,
If you want to be able to run multiple independent instances of a
sequence program, you have to flag it as re-entrant, by adding a line
"option +r;" after the program statement for example (you can also do it
with a command-line flag, but the option statement is simpler).
- Andrew
On 11/04/2014 12:11 PM, Damiano Bortolato wrote:
> Hi,
> I' trying to spawn a set of instances of a sequencer program from ioc
> shell, the program is like this:
> program myProgram
> int myVar;
> assign myVar to "myPv{n}";
> monitor myVar;
> ss mySs {
> Different input pvs are assigned to different program instances:
> epics> seq myProgram "n=_1"
> epics> seq myProgram "n=_2"
> epics> seq myProgram "n=_n"
> The problem is that the several instances seem to interfere each other,
> I tried to print the address of the input variable (myVar) and I noticed
> that they share the same myVar!!!
> I've tried to move the myVar's definition inside the state set but the
> problem persists.
> Is there a way to work around this problem, or must I run my sequencers
> as stand-alone applications?
> Thanks in advance
> Damiano
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
- Re: Sequencer: are variables shared? Damiano Bortolato
- Sequencer: are variables shared? Damiano Bortolato
MinGW PRODDIR_LDFLAGS Lang, Keenan C.
<2014>
<2014>
