On 01/09/2014 21:00, Mark Rivers wrote:
EPICS_HOST_ARCH env var is set and so is ASYN.
These should not be set as environment variables, they should be defined in the configure/RELEASE file of your application.
Well...
While definitions of external modules like ASYN should always go into
the configure/RELEASE file (it is named RELEASE because it defines the
exact releases of external modules that you are using), EPICS_HOST_ARCH
is meant to be set in the environment.
While setting it in configure/RELEASE might work, the host architecture
is rather a property of the host than a definition of an external module.
As soon as you put your sources on a network drive and compile it for
multiple host architectures inside the same structure, setting the host
architecture in configure/RELEASE is obviously not a good idea.
~Ralph
- RE: stream device get started? Mark Rivers
- stream device get started? Alireza Panna
Re: Making two computers communicate. Vlad Andrei Rusu
Re: Making two computers communicate. Ralph Lange
<2014>
<2014>
