1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: stream device get started?
To: Ralph Lange <[email protected]>, EPICS Tech-Talk <[email protected]>
Cc: Alireza Panna <[email protected]>
Date: Tue, 2 Sep 2014 11:15:05 +0000
Ralph is right, only ASYN should be defined in configure/RELEASE, EPICS_HOST_ARCH should be defined as an environment variable.
From: [email protected] [[email protected]] on behalf of Ralph Lange [[email protected]]
Sent: Tuesday, September 02, 2014 2:35 AM
To: EPICS Tech-Talk
Cc: Alireza Panna
Subject: Re: stream device get started?
On 01/09/2014 21:00, Mark Rivers wrote:
>> EPICS_HOST_ARCH  env var is set and so is ASYN.
> These should not be set as environment variables, they should be defined in the configure/RELEASE file of your application.
Well...
While definitions of external modules like ASYN should always go into
the configure/RELEASE file (it is named RELEASE because it defines the
exact releases of external modules that you are using), EPICS_HOST_ARCH
is meant to be set in the environment.
While setting it in configure/RELEASE might work, the host architecture
is rather a property of the host than a definition of an external module.
As soon as you put your sources on a network drive and compile it for
multiple host architectures inside the same structure, setting the host
architecture in configure/RELEASE is obviously not a good idea.
~Ralph
Re: stream device get started? Alireza Panna
RE: stream device get started? Mark Rivers
Re: stream device get started? Ralph Lange
Prev: Re: about caPutLog Ralph Lange
Next: RE: Making two computers communicate. Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: stream device get started? Ralph Lange
Next: Re: stream device get started? Alireza Panna
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
