1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: stream device get started?
To: Alireza Panna <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 1 Sep 2014 19:00:39 +0000
> EPICS_HOST_ARCH  env var is set and so is ASYN.
These should not be set as environment variables, they should be defined in the configure/RELEASE file of your application.
From: [email protected] [[email protected]] on behalf of Alireza Panna [[email protected]]
Sent: Monday, September 01, 2014 1:48 PM
To: [email protected]
Subject: stream device get started?
Hello all,
So I have used stream device successfully before on linux-x86_64 arch. I decided to try in on win32-x86 specifically win xp (base-3-14-12-4 complied with strawberry perl, MS Visual studio 2009, GnuMake and using stream-2-6 and asyn-4-23) Everything compiled successfully, however when I try to make the device support module, following the guidelines proposed in the How to Guide for Stream (http://www.aps.anl.gov/epics/modules/soft/asyn/HowToDoSerial_StreamDevice.html), I get the following error:
C:\Epics\extensions\IPL\Keithley\K2410>%ASYN%\bin\%EPICS_HOST_ARCH%\makeSupport.
pl -t streamSCPI K2410
expected 'makeSupport.pl', got 'C:\Epics\support\asyn-4-23\bin\win32-x86\makeSup
port.pl<http://port.pl>'
expected 'expected win32-x86', got ''
expected 'bin', got ''
: No such file or directory at C:\Epics\support\asyn-4-23\bin\win32-x86\makeSupp
ort.pl<http://ort.pl> line 51.
I get the same error when I try makeSupport.pl -l to list all template types.
It might be a path error on my side, but I can't seem to figure it out.
Any help will be appreciated.
Thank you
Alireza Panna
Alireza Panna
University of Maryland, College Park
Re: stream device get started? Ralph Lange
stream device get started? Alireza Panna
Prev: stream device get started? Alireza Panna
Next: RE: motorApp R6.8 Mclennan PM600 opposite limit datum search mode on linux-arm D'Ewart, J. Mitch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: stream device get started? Ralph Lange
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
