Hello Andrew:
Yes, that's exactly what we need.
Thanks for reading the release notes for me.
Sorry that you had to read the release notes for me.
-Kay
On Jun 11, 2014, at 11:28 AM, Andrew Johnson <[email protected]>
wrote:
> Hello Kay,
> Janet has made a number of changes to the dependency rules including
> those for templates since the 3.14.12.2 release that you appear to be
> using. I think we already did what you are suggesting - I just tried
> adding an external template file to a .substitutions file using the
> 3.14.12.3 release of Base and the generated .db.d file has the full
> path-name to the template file in it.
> The Release Notes for 3.14.12.3 included the following item which I
> think describes this issue:
>> Build problem with db dependencies
>> The dependency output for .db and .acf files created by
>> makeDbDepends.pl did not show the directories of the depended
>> files. The makeDbDepends.pl script has been replaced by mkmf.pl
>> for this purpose after modifying it to accept multiple -I
>> include directory options and more than one source file on the
>> command line. The makeDbDepends.pl script has been removed from Base.
> HTH,
> - Andrew
- Dependency issue with shared database templates unless using "make clean" Kasemir, Kay
- Re: Dependency issue with shared database templates unless using "make clean" Andrew Johnson
Re: Dependency issue with shared database templates unless using "make clean" Benjamin Franksen
lakeshore 336/350 support Pearson, Matthew R.
<2014>
<2014>
