1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Dependency issue with shared database templates unless using "make clean"
Date: Wed, 11 Jun 2014 14:53:31 +0000
Hi:
We have certain database templates that are shared, and run into a problem with the make system when trying to re-build them without a prior "make clean". As the project grows, it's very inconvenient that every change requires a full rebuild.
Assume we have some example.template in a shared location:
/path/to/my/support/example/db/example.template
In the configure/RELEASE file of a new application, we define its path:
# Where the shared templates are
SUPPORT_EXAMPLE=/path/to/my/support/example
In the application's Db directory, we have my_database.substitutions:
file example.template
.. and in the Makefile there's
TOP=../..
include $(TOP)/configure/CONFIG
DB += my_database.db
include $(TOP)/configure/RULES
A fresh build works OK:
$ make
perl ......R3.14.12.2/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[1]: Entering directory `....xxxxApp/Db/O.linux-x86_64'
echo "../O.Common/my_database.db : " >> my_database.db.d
Inflating database from ../my_database.substitutions
msi   -I. -I.. -I ../../../db  -I/home/controls/epics/R3.14.12.2/base/db    -I/path/to/my/support/example/db -S../my_database.substitutions  > my_database.tmp
mv my_database.tmp ../O.Common/my_database.db
Installing created db file ../../../db/my_database.db
But when trying to run 'make' again, this fails:
$ make
make[1]: *** No rule to make target `example.template', needed by `../O.Common/my_database.db'.  Stop.
The problem seems to be that makeDbDepends.pl, called from RULES.Db, creates a dependency file like this:
$ cat O.linux-x86_64/my_database.db.d
../O.Common/my_database.db: example.template
When msi is called, it received command line options like "-I/path/to/my/support/example/db" that allow it to find all dependencies, but when 'make' is looking at the my_database.db.d dependency file, it only has "example.template" without any idea where to find it, so it rightly complains "No rule to make..".
Would it make sense to invoke makeDbDepends.pl with options similar to the msi invocation, and update it to write the full path to all dependencies into the dependency file?
That way, makeDbDepends.pl could create a dependency file that lists the complete path names, i.e.
../O.Common/my_database.db: /path/to/my/support/example/db/example.template
and then make would be happy.
Kay
Re: Dependency issue with shared database templates unless using "make clean" Andrew Johnson
Re: Dependency issue with shared database templates unless using "make clean" Benjamin Franksen
Prev: Re: EPICS database Feature request Benjamin Franksen
Next: Re: Dependency issue with shared database templates unless using "make clean" Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: calc out record to verify pv not connected Andrew C. Starritt
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
