1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: motor record: soft motor & DMOV
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 27 Aug 2013 21:24:52 +0000
I'm using two hard motor records and two soft motor records in a
multi-axis configuration with some nasty non-linear coordinate transform
in between. From time to time my soft motor records get stuck in a weird
state:
-The record, the DINP fields of the soft records point to, has VAL=1.
-The MSTA field says the soft motor is done (MSTA=2).
-Nevertheless DMOV is off for both soft records.
-Neither sending a new position nor STOPing the soft motor works. The
only way I'm able to move the motor again is to restart the IOC to set
the DMOV field.
As far as I understand the Motor Record documentation DMOV should be the
same as the "done" bit in MSTA.
It somehow sounds similar to this issue:
http://www.aps.anl.gov/epics/tech-talk/2008/msg00238.php Unfortunately
it seems to be difficult to reproduce this issue :-(
Any ideas how this can happen?
Martin
P.S.: I'm using MotorRecord R6-8. See the attached file for the complete
output of dbpr. The full sources of the IOC can be found here:
https://github.com/mark0n/stripperFoilPlatterTestbed
ACCL: 0.2           ACKS: NO_ALARM      ACKT: YES           ADEL: 0
ALST: 0             ASG:                ASP: (nil)          ATHM: 0
BACC: 0.5           BDST: 0             BKPT: 00            BVEL: 0
CARD: -1            CBAK: 0x6e1ea0      CDIR: 0             CNEN: Disable
DCOF: 0             DESC:               DHLM: 0
DIFF: -0.43561908350066                 DINP:DB_LINK test:doneMoving_ NPP NMS
DIR: Pos            DISA: 0             DISP: 0             DISS: NO_ALARM
DISV: 1             DLLM: 0             DLY: 0              DMOV: 0
DOL:CONSTANT        DPVT: 0x6df9f0      DRBV: 13.076        DSET: 0x7ffff7310e40
DTYP: Soft Channel  DVAL: 13.076        EGU: in             ERES: 1.0e-03
EVNT: 0             FLNK:CONSTANT 0     FOF: 0              FOFF: Variable
FRAC: 1             HHSV: NO_ALARM      HIGH: 0             HIHI: 0
HLM: 0              HLS: 0              HLSV: NO_ALARM      HOMF: 0
HOMR: 0             HOPR: 0             HSV: NO_ALARM       HVEL: 0
ICOF: 0             INIT:               JAR: 0              JOGF: 0
JOGR: 0             JVEL: 0             LCNT: 0             LDVL: 13.076
LLM: 0              LLS: 0              LLSV: NO_ALARM      LOCK: YES
LOLO: 0             LOPR: 0             LOW: 0              LRLV: 0
LRVL: 13076         LSET: 0x6e03c0      LSPG: Go            LSV: NO_ALARM
LVAL: 13.076        LVIO: 0             MDEL: 0             MIP: 512
MISS: 0
MLIS: 20 23 03 d0 ff 7f 00 00 e0 1c 03 d0 ff 7f 00 00 03 00 00 00
MLOK: f0 b0 6d 00 00 00 00 00           MLST: 0             MMAP: 0
MOVN: 0             MRES: 1.0e-03       MSTA: 2             NAME: test:motorRad
NMAP: 0             NSEV: NO_ALARM      NSTA: NO_ALARM      NTM: NO
NTMF: 2             OFF: 0              OMSL: supervisory
OUT:DB_LINK test:fwdRad_ PP NMS         PACT: 0             PCOF: 0
PHAS: 0             PINI: NO            POST:               PP: 0
PPN: (nil)          PPNR: 0x7fff94034550                    PREC: 2
PREM:               PRIO: LOW           PROC: 0             PUTF: 1
RBV: 13.076         RCNT: 0             RDBD: 0.01
RDBL:DB_LINK test:rdPosPolar_.VALA NPP MS                   RDES: 0x69c270
RDIF: -436          REP: 0              RHLS: 0             RINP:CONSTANT
RLLS: 0             RLNK:CONSTANT       RLV: 0              RMOD: Default
RMP: 13076          RPRO: 1             RRBV: 13076         RRES: 1
RSET: 0x7ffff7bd2380                    RTRY: 0             RVAL: 13076
RVEL: 0             S: 0                SBAK: 0             SBAS: 0
SCAN: Passive       SDIS:CONSTANT       SET: Use            SEVR: NO_ALARM
SMAX: 0             SPMG: Go            SPVT: (nil)         SREV: 200
SSET: 0             STAT: NO_ALARM
STOO:DB_LINK test:stopPistonMotors_.PROC NPP NMS            STOP: 0
STUP: OFF           SUSE: 0             SYNC: 0             TDIR: 0
TIME: 2013-08-27 15:40:35.867431154     TPRO: 0             TSE: 0
TSEL:CONSTANT       TWF: 0              TWR: 0              TWV: 0.1
UDF: 0              UEIP: No            UREV: 0.2           URIP: Yes
VAL: 12.64          VBAS: 0             VELO: 0             VERS: 6.8
VMAX: 0             VOF: 0
record(motor, "$(PREFIX):motorRad") {
  field(DTYP, "Soft Channel")
  field(OUT, "$(PREFIX):fwdRad_ PP")
  field(RDBL, "$(PREFIX):rdPosPolar_.VALA NPP MS")
  field(RRES, "1")
  field(URIP, "Yes")
  field(PREC, "2")
  field(EGU, "in")
  field(RDBD, "0.01")
  field(TWV, "0.1")
  field(STOO, "$(PREFIX):stopPistonMotors_.PROC")
  field(MRES, "0.001")
  field(RTRY, "0")
  field(DINP, "$(PREFIX):doneMoving_")
  field(LOCK, "YES")
  field(NTM, "NO")
RE: motor record: soft motor & DMOV Mooney, Tim M.
Prev: RE: Unexpected Processing Trace (TPRO) Mark Rivers
Next: New edm widgets Young, James R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Omega CN616 support Phillip Sorensen
Next: RE: motor record: soft motor & DMOV Mooney, Tim M.
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
