1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Extensions Compilation Errors
To: murad ali <[email protected]>
Cc: [email protected]
Date: Tue, 30 Apr 2013 10:26:28 -0500 (CDT)
I see that your error messages refer to a config directory so I think you downloaded "Extensions build config files (R3.13)" which are very old files for EPICS R3.13 builds.  You should download the "Extensions build configure files (R3.14)". from the extensions web page.
After you download and unzip the file to create your extensions tree you should set EPICS_BASE in the extensions/configure/RELEASE file to your EPICS base top directory.
----- Original Message -----
To: [email protected]
Sent: Tuesday, April 30, 2013 2:26:22 AM
After Making Some changes here and there in RElease files
Now I am Stuck Here for compiling MEDM:
root@murad-desktop:/opt/epics/extensions/src/medm# make
../../config/CONFIG_EXTENSIONS:68: /opt/epics/config/CONFIG: No such file or directory
Makefile:16: /opt/epics/config/RULES_DIRS: No such file or directory
make: *** No rule to make target `/opt/epics/config/RULES_DIRS'. Stop.
On Mon, Apr 29, 2013 at 8:52 AM, murad ali < [email protected] > wrote:
I have Ubuntu 11.4 Installed. I want to Install EPICS Base and MEDM following Instructions on (Download the distributions tarballs from EPICS.doc attached) . please refer to Configure the Extensions Section in this File.
EPICS Base is Installed and Compiled (Base Installation Attached)
While Compiling MEDM the erorr occures during make (extensions error attached)
kindly let me tell that how can I compile MEDM properly.
Also what are other alternatives to MEDM. CSS is just like MEDM or some other thing.
An Early Response is required
Regards
Murad Ali
Re: EPICS Extensions Compilation Errors murad ali
Prev: Re: Redundancy Scott Baily
Next: Would like to add regular expressions to dbpr Zelazny, Michael Stanley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS Extensions Compilation Errors murad ali
Next: Re: EPICS Extensions Compilation Errors Pete Jemian
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
