1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Extensions Compilation Errors
To: [email protected]
Date: Wed, 01 May 2013 02:08:18 -0500
Murad:
There are several errors in your setup that cause the problems you reported. Others have identified problems with your extensions configuration. The first problem is that you have not defined the EPICS_HOST_ARCH environment variable before you built EPICS base. Here's what goes into your ~/.bash_aliases file to make this definition:
export EPICS_HOST_ARCH=`/usr/local/epics/base/startup/EpicsHostArch`
Privately, you asked for more assistance in identifying the resources
needed to build EPICS base and MEDM on Ubuntu 11.4 and also asked about CSS-BOY. Digging through the Ubuntu mirrors today, there is no 11.04 release available (don't know why that is missing) but there are 11.10 versions.
Documentation describing the download, installation, compilations, and testing steps for recent releases of EPICS base, MEDM, and CSS-BOY on Ubuntu 11.10 is now available. This includes the additions of Ubuntu packages and libraries needed after a fresh installation.
See:  http://tinyurl.com/ioctest
Demonstration of the softIoc executable from EPICS base is included.
   Pete
On 4/29/2013 3:52 AM, murad ali wrote:
I have Ubuntu 11.4 Installed. I want to Install EPICS Base and MEDM
following Instructions on (Download the distributions tarballs from
EPICS.doc attached) . please refer to Configure the Extensions Section
in this File.
EPICS Base is Installed and Compiled (Base Installation Attached)
While Compiling MEDM the erorr occures during make (extensions error
attached)
kindly let me tell that how can I compile MEDM properly.
Also what are other alternatives to MEDM. CSS is just like MEDM or some
other thing.
An Early Response is required
Regards
Murad Ali
Pete R. Jemian, Ph.D.                <[email protected]>
Beam line Controls and Data Acquisition, Group Leader
Advanced Photon Source,   Argonne National Laboratory
Argonne, IL  60439                   630 - 252 - 3189
   Education is the one thing for which people
      are willing to pay yet not receive.
EPICS Extensions Compilation Errors murad ali
Prev: Would like to add regular expressions to dbpr Zelazny, Michael Stanley
Next: Re: vishnu chaudhari
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS Extensions Compilation Errors Janet Anderson
Next: Re: EPICS Extensions Compilation Errors murad ali
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
