1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: autosave limitation?
To: Emmanuel Mayssat <[email protected]>
Cc: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 12 Apr 2013 08:30:40 -0400
Hi:
Depending on what version of autosave you are using, you can work without any standalone autosave config files.
Instead, you add annotations to your database records:
record(type, "$(S):SomeRecord")
    info(autosaveFields, "VAL LOW")
The granularity of autosave configuration files is thus just the database files:
One database per device? -> That database file also contains the autosave info.
When you create new *.db files, it is easy enough to add those info annotations right away.
If your application uses existing *.db files that you don't want to edit, note that you can load multiple definitions of the same record. You can load a second database file that contains the same record names, but only the missing info annotations:
In your IOC startup file you then add a command that auto-creates the request files from those database annotations:
makeAutosaveFileFromDbInfo("autocreated.req", "autosaveFields");
create_monitor_set("autocreated.req.req", 5)
-Kay
On Apr 11, 2013, at 19:43 , Emmanuel Mayssat wrote:
> I have several device running in a master IOC.
> I would like to use autosave.
> The issues is that I would like to break down my master IOC into smaller ones at will (for development purpose).
> I would like to use several req files and restore files for autosave.
> In other words, I would like to have one autosave configuration per device in the master IOC.
> Q: Is there a limitation to the number of files and instance of autosave in a single IOC?
> Regards,
> Emmauel
RE: autosave limitation? Emmanuel Mayssat
Prev: autosave limitation? Emmanuel Mayssat
Next: CSS BOY - global widget properties modification Vítek Michal
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: autosave limitation? Emmanuel Mayssat
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
