1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: CSS BOY - global widget properties modification
Date: Fri, 12 Apr 2013 14:31:30 +0000
Hello,
I am working on a HMI that will be used in a laser lab by a personal with protective glasses (no colors are visible). Therefore I would like to modify widgets behavior regarding the alarm indication. My idea is to have the border of the widget blinking and to show also small pictogram indicating type of the alarm in the upper left corner of the widget. Thus I think I will need to modify abstract classes that are extended by the widgets to add this functionality. Does anyone know what class/classes needs to be changed? Or is there any other recommanded way? (I can make the blinking effect easily with the rules, but how to show a pictogram I do not know…).
Cheers,
Mike
Re: CSS BOY - global widget properties modification Kasemir, Kay
Prev: Re: autosave limitation? Kasemir, Kay
Next: Re: autosave limitation? Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: autosave limitation? Tim Mooney
Next: Re: CSS BOY - global widget properties modification Kasemir, Kay
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
